Jeff Frost
Old Oct 5, 2018 | 01:23 AM
Jefffrost's Avatar
Default Jeff Frost
I have just bought a 1963 MK2 the steering column Indicator/ Flasher switch wiring has been completely disconnected can any one tell me where there is perhaps a schematic diagram so I can connect all the wires
Old Oct 5, 2018 | 02:03 AM
Welcome to the forum Jeff,
I've moved your question from General Tech Help to MKI / MKII S type 240 340 & Daimler forum. This is the place to post technical questions about your model.
Old Oct 5, 2018 | 02:14 AM
JeffR1's Avatar
https://www.jaguarforums.com/forum/m...k-links-67791/
Click on the link and you will find parts and service manuals there in pdf form.
Unless the old braded cloth wiring is really dirty, you should be able to match up the colour codes on the wires to simply connect the bullet connectors.
Mine used braded cloth and some plastic.
At any rate with the wring diagram, and some continuity testing with a multi meter, you should be able to get the job done.
It's pretty simple compared to a modern day car.
Old Oct 5, 2018 | 07:47 AM
Glyn M Ruck's Avatar
I think the column should be the same as an S Type. See Hi Res pdf. attached. Much easier to follow than B&W manual. Credit ~ Jaguar S Type Register.
Old Oct 5, 2018 | 11:08 AM
Default M2 Electrical Guide
File Type: pdf
Old Oct 5, 2018 | 06:43 PM
Jose's Avatar
MK-2 Electrical Schematic
Old Oct 6, 2018 | 02:37 PM
csbush's Avatar
If you bought the switch from SNG Barratt, ask them if they have a wiring diagram. Sometimes the new switches have different color wires and they have the key.
Calvey
Apr 29, 2017 10:28 PM
gt1000
Feb 6, 2015 10:33 PM
PaulCarr
Dec 18, 2014 07:36 PM
Sonspit
Aug 9, 2014 05:32 AM
Fezz
Jul 20, 2013 04:31 PM
