Knock Off Removal Tools
Old Aug 9, 2022 | 04:09 PM
JeffR1's Avatar
On the splines yes. On the knock on threads ideally no. It alters the torque. If you do lubricate the threads tighten even less. I don't advocate lubricating spinner/hub threads. They are not in motion with one another.
I like solids that are fully drying like off-road chain sprays & similar on the splines ~ Once again there are some special products for the job from Bechem etc. that are hell to get hold of. I've got dry lubricated splines but got a friend in the industry to make it up for me. He has an Aerosol filling plant.
Originally Posted by Jagboi64
I've used a copper based anti-seize that I brush on. Any thoughts on it? here is the tech sheet: https://docs.jetlube.com/documents/T...DS_English.pdf
I would put some sort of lube on them, I have copper anti-seize on my brass lug nuts, and I would put it on my spinners.
I believe any thread that is in use like that needs lubrication to keep the threads from galling, and premature wear.
In that case Glen, they would not need to be torqued down as much, thus making them last longer.
Old Aug 9, 2022 | 06:21 PM
Glyn M Ruck's Avatar
Fine for splines. I would not use on spinner & hub threads. Products containing 3 to 5% by mass of molybdenum disulphide will do a better job than copper but copper is fine in that application. Your splines will be fine. I have Moly on my splines in a drying & coating base that sticks like **** to a blanket.
Old Aug 9, 2022 | 06:27 PM
You may do as you wish Jeff. Your torque assumption is wrong ~ We are talking spinners & hubs here ~ nothing else. The spinners & hub threads require zero lubrication. They are not in motion with one another and as MWS points out the spinners will find their own ideal torque by driving. They are 100% right. Galling is a form of wear caused by adhesion between sliding surfaces. When a material galls, some of it is pulled with the other contacting surface.
Lubricating spinner & hub threads will increase torque as they will tighten further with use. All torque values for nuts, bolts etc. etc. are specified dry unless otherwise stated. If you are worried about water ingress or whatever creeping into threads after torquing apply protection like Tectyl after torquing externally.
e.g. If you lubricated your head dome nuts you would be over torquing vs specification.
DavidN
Sep 17, 2016 09:12 AM
loveatfirstsight
May 29, 2011 01:42 PM
Hawkeye
May 4, 2009 08:28 PM
