MK2 Center console differences?
Are the MK2 center consoles significantly different on cars fitted with automatic and manual transmissions? I purchased a set of metal radio console side trim panels that I was told were taken off a MK2, but they are 2-3 inches too tall.
Thanks.
Thanks.
Yes it is. Certainly the Daimler 2.5 litre saloon that used the Mark 2 shell had a different tunnel which was much smaller as the engine was a small V8 hence the gearbox sat further forward hence less space was needed for it in the tunnel.
I have a jaguar auto model. The console(Containing the gear shift,for manual, and ashtray) is the same for both manual and auto. Turn the auto version upside down and you will see that the auto version has the cut out for the shift. I have both in my possesion, that part is the same.
I also have the cheeks, or side panels for the radio panel, these also appear to be the same.The bottom of these side panels come down to meet the bottom of the gear shift part.
Bearing in mind what I have said then the general( But perhaps not ALL)dimensions re the tunnel and console are similar.
The daimler version has a different tunnel and configuration.
barry
barry
I think there must have been a change in the design of the tunnel around 1962. The parts book definitely shows two different sets of numbers for the side panels (cheeks) depending on chassis number.
Interesting, and important if you're looking for used replacements.
Barry -As a reference point what's your chassis number and the vertical length of the left side panel?
Thanks.
Thanks.
These pictures show the differences between a manual gearbox console (from Nigel Thorley "Original Jaguar Mk1/Mk2") and mine (which uses the original console recovered). My car (The tan interior) is a 1960 3.8 with a DG 250 auto transmission. Note also that the whole console looks different and is not as high on the auto transmission since it seats on the wider tunnel required by the DG 250. The tunnels have also a different shape.
JP
1960 3.8 auto
JP
1960 3.8 auto
First 3 digits are 205, its a 1961 DG auto. Height of side panel is 9 3/4".
The shape is similar to the Tan , bottom in line with centre console.
Barry
Barry
hunter34
19
Sep 14, 2022 11:09 PM
MI-FType
Sep 13, 2015 11:26 PM
280zx-turbo
Sep 10, 2015 06:29 AM
1964Daimler
Sep 9, 2015 11:28 AM
