MK2 Gearbox: Need help
Old Mar 25, 2014 | 02:14 AM
ollibee's Avatar
Default MK2 Gearbox: Need help
Hi,
Who can help me? I have some gearbox assembly problems:
1. in the top cover are two ***** (#32) between the rods of the selector arrangement. How can they be mounted so they will not always fall down and how must be the position of the changespeed forks (#23, 24 and 25) when mounting the cover to the gearbox?
2. what position must the gears (#6, 16 and 24) in the gearbox have, so the cover can be mounted?
Thank you!
Regards,
Oliver
Attached Thumbnails MK2 Gearbox: Need help-mk2_gbsel.jpg   MK2 Gearbox: Need help-mkii_gb.jpg
Old Mar 25, 2014 | 09:32 AM
Jagfixer's Avatar
Use grease on bearing/*****. All else goes in exactly like picture. If mainshaft is assembled and in block, top will slide right into place. You can see where forks go when installing.
Stoney85
Jun 10, 2021 09:14 PM
Stoney85
Australia - Queensland
Jun 7, 2021 11:49 PM
1964Daimler
Sep 9, 2015 11:28 AM
yarpos
Aug 28, 2015 05:53 PM
MK2
Jan 17, 2013 02:35 AM
