MK2 Sidelamp seals
Old Jan 30, 2016 | 07:34 PM
MK2's Avatar
MK2
Default MK2 Sidelamp seals
The replacement rubber gasket “O” rings for these little lamps provided by SNG Barratt are to thick (wide). What are folks using for this seal between the lamp fixture and the body?
Thanks very much for suggestions.
Lin
Old Jan 30, 2016 | 08:13 PM
JeffR1's Avatar
With my Bentley, I just went to the hardware store (automotive store too) and got some smaller "O" rings.
A better way is to find some bulk neoprene (thin enough).
Clamp it between two pieces of wood and with you drill press use a forstner bit to get a nice clean hole the size you need, then use a very sharp pair of scissors to create the OD.
I have done this before and it's OCD, but it works quite well.
A hole saw works, if you can find one small enough.
Old Jan 30, 2016 | 11:28 PM
Curmudgeon's Avatar
The ones on the point of the wings?
They ARE thick. What doesn't fit?
They actually fit between the wing, housing AND the lense surround. Stick out a bit around the edge.
Old Jan 31, 2016 | 06:43 AM
MK2's Avatar
MK2
Thanks guys,
I will give my local hardware store a try first.
Lin
Katitud
19
Sep 11, 2016 06:02 AM
Moto Martin
Feb 21, 2016 12:23 AM
phu5ion
Feb 9, 2016 02:22 PM
rsmartin
Feb 1, 2016 11:29 PM
wcourt3010
Canada
Jan 27, 2016 02:13 PM
