MK2 Stock wheel opening measurements needed
Old Dec 9, 2014 | 09:38 PM
lickahotskillet's Avatar
Default MK2 Stock wheel opening measurements needed
Good evening,
Too much of a hurry here! Stripped the car before I made measurements for the direction I am going with this car.
I'm trying to determined how centered the wheels are in their respective openings. I need the following measurements (both front and rear) from a relatively stock MK2, with original or near original size tires, with the car on level ground. Mine is a 1960 MK2.
Front
Top of the wheel arch to the center of the wheel.
Front of the wheel arch to the center of the wheel, parallel to the ground.
Rear of the front wheel arch to the center of the wheel, parallel to the ground.
Rear
Top of the wheel arch to the center of the wheel. Measured at the top of the spat/outside finished edge of the fender/body.
Front of the wheel arch to the center of the wheel, parallel to the ground. Again to the finished edge of the fender/body.
Rear of the wheel arch to the center of the wheel, parallel to the ground. Again to the finished edge of the fender/body.
Please indicate the year of your car and tire size for reference.
Thanks in advance,
Regards,
Clyde Gantz
Old Dec 10, 2014 | 01:50 AM
Hawken's Avatar
Hi Clyde, Hope this helps
Front
Top of the wheel arch to the center of the wheel. 380mm
390mm the wheel center is lower than the bottom of the guard so this is to the bottom of the bumper. (lines up with the center)
Rear of the front wheel arch to the center of the wheel, parallel to the ground.340mm
Rear
Top of the wheel arch to the center of the wheel. Measured at the top of the spat/outside finished edge of the fender/body.405mm
Front of the wheel arch to the center of the wheel, parallel to the ground. Again to the finished edge of the fender/body.425mm
Rear of the wheel arch to the center of the wheel, parallel to the ground. Again to the finished edge of the fender/body.410mm
My car is a 61 Mk2, It appears to have standard suspension and I'm running Michelin 185/80 15s
Ken
Old Dec 11, 2014 | 08:00 PM
Front
Ken
Ken,
Many thanks for the effort to get these numbers to me. Looks like exactly what I needed!
Regards,
Clyde Gantz
BrentGardner
29
Dec 16, 2024 12:13 AM
Doberman_Fan
22
Dec 24, 2019 06:21 AM
Griffbritgreen
Jul 27, 2016 05:43 AM
EastFalk
Aug 29, 2015 08:22 PM
divingmom
Aug 25, 2015 07:54 PM
