Mystery Wire - 64 MK2
Hi folks,
Thought I had labeled everything clearly, but guess not. I have attached two photos. My question is what is the termination of the green wire coming from the firewall to the RH valance? I know the white/brown wire attaches to the oil pressure sender. I assume the green wire is all green but it is hard to tell in the photos. It could have a tracer color.
Thank you!
Thank you!
Temperature sender or the thermostatic choke switch in between the carbs _ the thermostatic sensor by the thermostat housing _ assuming that your model has this type of choke.
A simple continuity test will tell you which is which and/or you can look in the wiring diagram, it will tell you for sure.
If you still can't figure it out, I'll look for you.
1964Daimler
Sep 9, 2015 11:28 AM
