Mystery Wire - 64 MK2
Old Jun 27, 2015 | 01:27 PM
MK2's Avatar
MK2
Default Mystery Wire - 64 MK2
Hi folks,
Thought I had labeled everything clearly, but guess not. I have attached two photos. My question is what is the termination of the green wire coming from the firewall to the RH valance? I know the white/brown wire attaches to the oil pressure sender. I assume the green wire is all green but it is hard to tell in the photos. It could have a tracer color.
Thank you!
Attached Thumbnails Mystery Wire - 64 MK2-rh-wall-wiring-path-3-clips.jpg   Mystery Wire - 64 MK2-img_1699-1-.jpg
Old Jun 27, 2015 | 01:37 PM
JeffR1's Avatar
Temperature sender or the thermostatic choke switch in between the carbs _ the thermostatic sensor by the thermostat housing _ assuming that your model has this type of choke.
A simple continuity test will tell you which is which and/or you can look in the wiring diagram, it will tell you for sure.
If you still can't figure it out, I'll look for you.
Old Jun 27, 2015 | 08:14 PM
MK2's Avatar
MK2
Default Mystery Wire-64MK2
The wiring is not yet assembled and no engine in the car. I have looked at the wiring diagram. Still not sure.
Lin
Rivguy
Nov 13, 2022 02:55 AM
Steve10
Sep 20, 2015 12:27 PM
dstary
Sep 19, 2015 09:47 AM
1964Daimler
Sep 9, 2015 11:28 AM
