oil leak
Old Apr 15, 2020 | 08:34 PM
pyohannes's Avatar
Angry oil leak
i recently had gear box replaced on my 1966 mark 2. I now have oil leaking like a faucet when engine is on and immediately stops leaking when engine is turned off. Any ideas? there is also a rattling noise in idle position that goes away when clutch pedal is pressed. Noise still present, though not as pronounced, in first gear. any diagnostic suggestions or solutions?
Old Apr 15, 2020 | 08:45 PM
Glyn M Ruck's Avatar
Some layshaft rattle at idle clutch out, is common with these gearboxes even with new bearings etc. Where is the oil leaking from? Front of gearbox/bellhousing, rear of GB? Is the car OD?. GB has pressure oil feed or if with OD it uses the OD pump to circulate oil.
Is it leaking engine oil or gear oil? Gear oil will have a strong sulfurous smell.
Slownot
Aug 10, 2018 11:14 AM
Len Apcar
Mar 19, 2018 06:00 PM
brinny
Apr 22, 2016 07:07 AM
drinkycrow
Oct 28, 2015 08:49 PM
daboss085
Aug 31, 2013 06:35 PM
