Radiator cap pressure for 3.8L engine. 7 lbs. too much ?
Old Oct 8, 2024 | 11:14 AM
Schmitty's Avatar
Default Radiator cap pressure for 3.8L engine. 7 lbs. too much ?
I currently have a 4 psi cap that I sourced from SNG. I installed a radiator reservoir / overflow tank to capture the expelled coolant and then have it returned to the radiator as matters cool off. A guy in the local Jaguar club helped me install this system and recommended a Stant cap # 10206, which is what he uses on his Mark 1 3.4 with a similiar system. Researching this cap I find that it is a 7 psi cap and I'm wondering if that bump up in the psi would be OK on My Jaguar Mark 1 with the 3.8 engine ? Thanks,
Schmitty
Old Oct 8, 2024 | 03:21 PM
Cass3958's Avatar
I have a similar system that I fitted to my 3.4s. I have two 7lb caps one on the radiator and one on the expansion tank and I have not had any problems with mine. It has been fitted and running not for three years and I have not had to top the water up in the expansion tank once and the radiator remains full all the time.
Felixbobcat
Sep 27, 2022 05:41 PM
95 Cat
Oct 8, 2021 12:02 PM
racerxf12004
E type ( XK-E )
Aug 20, 2019 09:43 AM
Harry Peter Rose
Feb 15, 2018 05:46 PM
barrymk2
Apr 3, 2014 02:39 AM
