1986 xjs v12jaguar
Old May 22, 2014 | 12:12 AM
zipper1462's Avatar
Default 1986 xjs v12jaguar
hello my name is bernard button and my ride is a 1986 xjs v12 in mint condition except when i bought it the heat and air didnt work the garage put in a new servo and now the heat works the freon is not leaking and the compesor is running but only heat comes out , what could be wrong , also i put in after draining feron 3 oz oil and 30 oz freon is that enough. i can see the freon moving threw the site glass
Old May 22, 2014 | 12:19 AM
zipper1462's Avatar
well i thought i did this right my question is in the thread but here it is again ive a 1986 xjs v12 i have 30 oz of freon in and 3 oz of oil not leaking and can see freon moving in site glass and compessor is running and only heat is coming out and the garage put in a new sevo just before winter then the heat worked but i didnt check a/c untill now and i drained system and filled how i told you what could be wrong with ac
Old May 22, 2014 | 02:06 AM
First of all, welcome.
The word "servo" has me stumped a tad, as the '86 is known as the Delonair 2 system, which is primarily vacuam operated.
Maybe the heater tap is jammed OPEN, very common.
As for the Freon, NO idea. All a/c work down here is regulated and a license is required to work on the system.
From the OLD OLD days of R12, any bubbles in the sight glass meant the system was "under charged", but gauges on the HI and LO side are really needed to get it right. Also we used to vac the system down prior to recharging.
Someone in your market will cruise by soon and answer.
I also suggest that "questions" are posted in the related forum section, XJ-S in this case, that way many more people see it, as not everyone comes in here that often.
Old May 22, 2014 | 02:40 AM
Welcome to the forum Bernard,
Grant has already given you some advice but I've copied your question to the XJS tech section to get more input. Here is a direct link to it:
https://www.jaguarforums.com/forum/x...ng-out-118341/
Follow this link XJS - Jaguar Forums - Jaguar Enthusiasts Forum to the main XJS forum for help, advice and information.
You can also visit the US North East Region forum by following this link https://www.jaguarforums.com/forum/north-east-us-me-nh-vt-ma-ri-ct-nj-ny-pa-35/
Enjoy the forums.
Old May 22, 2014 | 06:22 AM
welcome to the forum, you will find plenty of info and support here simply follow the links Graham has provided - enjoy!!
Old May 22, 2014 | 09:36 PM
Welcome to Jaguar Forums Bernard,
Old May 23, 2014 | 04:29 PM
Bad Cattitude's Avatar
Welcome!
Old May 23, 2014 | 07:55 PM
Helpful_information
Old May 27, 2014 | 08:28 AM
Schwabe's Avatar
welcome and enjoy the board
rusty37
Apr 5, 2020 07:40 PM
Miles86XJ6
Sep 14, 2015 01:08 PM
bigmikeyt
Sep 14, 2015 12:06 PM
Ipc838
Sep 13, 2015 03:27 PM
prettydaim
Sep 7, 2015 05:16 PM
