1997 Jaguar Venden Plas Won't Start
Old Dec 11, 2013 | 02:58 PM
AndrewAuto's Avatar
Default 1997 Jaguar Venden Plas Won't Start
Ok, I am new here and not sure I am posting in the right section... Feel free to guide me where I need to be. I have a 1997 Jaguar Vanden Plas 4.0L straight 6. The car was having high idle issues, so I found out the IACV motor was stuck open causing the idle issue. After removing the throttle body and cleaning the IACV I reinstalled it. My issue now is the vehicle will not start. I have checked all fuses, spark, fuel pressure and it all checks out. When I check pulse on the injectors, the noid will pulse once while cranking and then stops. I am at my wits end with this vehicle and could use some professional help. Thank you
Old Dec 11, 2013 | 03:02 PM
jimbov8's Avatar
Hi Andrew and welcome to the forum.
If I were you I would start by going back over what you have already done and check everything again. You may well have forgotten something or disturbed something else.
Old Dec 11, 2013 | 03:11 PM
AndrewAuto's Avatar
I have triple checked everything on the original work I did around the throttle body. My only issue is why the injector only pulses once? my knowledge on these cars is very limited.
Old Dec 11, 2013 | 03:15 PM
Welcome to Jaguar Forums AndrewAuto,
You won't get a lot of technical advice here, head on over and post up your problem in the tech section XJ X300 / XJR - Jaguar Forums - Jaguar Enthusiasts Forum
Don't forget to check your regional section also Canada - Jaguar Forums - Jaguar Enthusiasts Forum
Old Dec 11, 2013 | 05:51 PM
Welcome to the forum AndrewAuto,
Good to have you here with us at Jaguar Forums.
Follow Norri's link to the X300 forum for help, advice and information.
Enjoy the forums.
Old Dec 11, 2013 | 06:16 PM
welcome to the forum and the Jag family - plenty of info and support here - simply follow the links Norri has provided - enjoy as this is the best tool in an owner's tool box!
Old Dec 11, 2013 | 07:59 PM
search facility etc, can be found here within the following link Helpful_information
See you in the forums....
1964Daimler
Sep 2, 2015 11:41 PM
201motels
Aug 30, 2015 08:03 PM
Newsguy
Aug 30, 2015 11:27 AM
rwoodlin
Aug 29, 2015 04:32 PM
Drew2006
Aug 28, 2015 04:22 PM
