Blown Fuses and Locked doors
Old Nov 1, 2012 | 05:24 AM
Jacknoclue's Avatar
Default Blown Fuses and Locked doors
Hi my name is Jack and I am new to this forum.
I have just inherited my dads 1997 Jaguar XK8 Convertible but have run in to a few problems.
I can not open the drivers door even with the key, fortunately the drivers side window is down so I can still get inside but just not open the doors or the fuse boxes inside.
There are also some blown fuses, which when I try to replace they just blow again instantly. These are mainly the ECU fuses. I am replacing them with the same rated fuses.
Nothing happens when I put the key in the ignition and turn it only a few things work such as the radio and blowers and after a couple of seconds a beeping comes on for a few seconds
The car did start but I found out that the guys that moved it connected a 24V!!! battery to the old one as the car was flat ( I think they did it on purpose ). Is it likely that they would have blow the ECU or is there a "main" fuse that would cause this to keep shorting out.
Thanks.
Old Nov 1, 2012 | 05:33 AM
steveinfrance's Avatar
Welcome to this friendly Forum, Jack.
I fear if someone was crazy enough to connect 24V to your vehicle the results will be catastrophic.
I suggest you go to the XK8 section and start by downloading JTIS from the stickies at the top.
XK8 / XKR - Jaguar Forums - Jaguar Enthusiasts Forum
There's a wiring diagram in the JTIS.
Also post your problem there with the position and numbers of the fuses that keep blowing and we'll try to help but I fear your car is in a seriously bad way.
Old Nov 1, 2012 | 05:36 AM
Welcome to the forum Jack,
Nice car but you clearly need some help from the electronics gurus here.
Follow this link XK8 / XKR - Jaguar Forums - Jaguar Enthusiasts Forum to the XK8/XKR section for help, advice and information.
You can also visit the UK Region section by following this link UK - Jaguar Forums - Jaguar Enthusiasts Forum to find other members in your region.
Old Nov 1, 2012 | 05:51 AM
Hi & welcome aboard Jack
Its good to have you here with us here at Jaguarforums.
Congrats on the Jag, but sorry to hear of your issues.
Please visit the XK8/XKR section where the gurus there will give you all the help you need
See you in the forums
Old Nov 1, 2012 | 10:36 AM
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
Mugatu
22
Jun 23, 2020 01:50 PM
kevinl
Oct 31, 2019 06:15 PM
XJsc-guy
Nov 23, 2015 01:56 PM
