Hey!
Old Jul 11, 2011 | 03:54 PM
mdallman's Avatar
Default Hey!
Okay so a bit of background on me: 20 year old kid may very well purchase a 2000 XJ8 L. While I understand that this is not a budget car, I am not worried about gas mileage, my previous car was a ford mustang, and from what I've read most of the problems except for the electrical issues can be prevented and caught before anything catastrophic happens. I am very mechanically inclined, I have worked on multiple types of engines and I research everything to a T before going about it, my mother on the other hand has asked a few people she knows with a Jaguar and is against the idea and while I am not quite sure of their mechanical aptitude, I doubt any of them have ever picked up a wrench, and their opinion is one that is shaded by the fact that they have always taken their cars to mechanics and paid thousands for repairs when in fact if they had taken a little time to get to know their cars those thousands in repairs may have been prevented.
Now as soon as I purchase the car I plan on checking to see if the secondary timing chain tensioners have been replaced with the third gen. type, and if not, using the zip tie method or actually buying the tools recommended to do the job I will be replacing them. The car was previously used I believe by a limo service or some such type and maintained in a fleet, so i have no records of any maintenance except for what the carfax states, which isn't much. The second major issue I plan on looking at is the ill designed forward drum on the transmission by draining the fluid and dropping the pan to check for debris. Is there anything anyone recommends I do other than those two major things?
Old Jul 11, 2011 | 05:13 PM
motorcarman's Avatar
Sounds like you have done your homework!!!! I bought my first Jag (1966 E-Type) way back in the early 70's when they were just used cars. You can't tell when the 'A'drum will fail and pulling the pan will only give an indication of friction material wear (but that will tell alot) or other components that might be breaking into debris chunks.
Keep us up to date on your decision!!!
bob gauff
Old Jul 11, 2011 | 06:16 PM
welcome aboard JF good to have you here as part of the forum
sounds like you done some homework to date and that coupled with good wrenching skills, time, patience and some input from this forum and other sources could very well save you $$$$
Loads going on, plenty of very friendly and helpful members as well as some excellent tech advice......all good!
In the meantime I've manually upgraded you to full forum access so you can better view the site
Old Jul 12, 2011 | 05:42 AM
Welcome to the forum,
Good luck with the car, I see that like almost every other 20 year old, you are not paying too much attention to your mother's advice.
Old Jul 12, 2011 | 09:13 PM
Gus's Avatar
Gus
Hello and welcome to jaguarforums.com.
Marque
Oct 11, 2015 05:59 PM
Spazzzzzzzzzy
Oct 4, 2015 05:37 PM
Johncy2000
Oct 2, 2015 01:05 AM
baskervillema
Oct 1, 2015 06:43 PM
Malihide
Sep 29, 2015 03:21 PM
