New in N. Carolina with 1994 XJS V12 conv. Only starts cold
Old Aug 22, 2018 | 05:34 PM
JagDE45's Avatar
Default New in N. Carolina with 1994 XJS V12 conv. Only starts cold
I am Don Ellington in mountains of North Carolina with a 1994 XJS V12 6L convertible with 65,000 miles.
I have had her since 8,000 miles in 1995 and given her great care and garage.
Check engine code FF77 came up
Mechanic replaced crank shaft position sensor #CSS961
Check engine light is out now but she only starts when cold......she will run as long as you want but if you cut her off once warmed up she will not start until you wait a long time to cool down and then she starts.
Since then we replaced both fuel pumps,strainers, and filter
Now mechanic says find a fuel pump module.....maybe that's it.
I can t find one and pray my problem could be something else.
Is it a coincidence that replacing the crank position sensor and the starting problem when warm happened at same time.
Or .....what could be causing this
I am desperate to save my baby from the junk or dismantle yard
Please help
Don Ellington
Old Aug 22, 2018 | 05:42 PM
Welcome to the forum Don,
I've copied your post to XJS forum for advice from members with the same model. Here's the direct link to it:
https://www.jaguarforums.com/forum/x...s-cold-206989/
Follow this link https://www.jaguarforums.com/forum/xjs-x27-32/ to the main XJS forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for information on regular issues.
You can also visit the US Lower Atlantic Region forum by following this link https://www.jaguarforums.com/forum/usa-lower-atlantic-nc-sc-fl-ga-66/ to find other members in your region.
Enjoy the forums.
Old Aug 22, 2018 | 10:32 PM
Hello, Don,
A little problem like that won't sentence your Jag to the wrecking yard! Certainly not considering the loving care you've given it. You'll get a handle on all that very soon I'm sure.
Old Aug 23, 2018 | 02:54 AM
Daf11e's Avatar
Welcome aboard Don.
Old Aug 23, 2018 | 04:07 AM
o1xjr's Avatar
Welcome to the forums.
Old Aug 23, 2018 | 04:28 AM
Welcome to Jaguar Forums Don,
Old Aug 23, 2018 | 05:14 AM
Welcome to the Forums.
Old Aug 23, 2018 | 06:32 AM
JagDE45
Aug 26, 2018 08:28 AM
marmar1305
May 6, 2017 05:44 PM
JaredsJag94
Jan 24, 2017 03:09 PM
notch383
Oct 15, 2014 10:08 PM
malibudav
XJ40 ( XJ81 )
Apr 22, 2012 10:39 PM
