Two 2001 XKR's convertibles
Old Jul 23, 2011 | 12:07 PM
Zeecat's Avatar
Default Two 2001 XKR's convertibles
Father-daughter XKR owners, hers optioned with the Brembo brakes/BBS 20" wheels. "Common" problems appear almost simultaneously on both Jags and it's good that I'm a do-it-yourself auto repairman. Longest repair was replacing the convertible top latch hydraulic hoses, at least a 6-pack job. Great info on this site to help diagnose failure issues.
Old Jul 23, 2011 | 09:30 PM
Gus's Avatar
Gus
Hello and welcome to jaguarforums.com. I know that you are anxious to get started and we are anxious to meet you and talk about your car. We have a baseline / criteria that must be met before full access can be granted. Please enjoy the forum and be patient once the baseline has been satisfied full access will be granted. Please continue to post and accept my welcome to the forum.
One other thing you need to put your car details in your signature. I am speaking of the Year, Make & Model. Without it you may not get the input you are looking for.
Also, should you have questions related to your vehicle please post it in the section for your model year (MY) car. This way you will reach all the members that are familiar with your MY car.
Good to know that we could help!
Old Jul 24, 2011 | 07:22 AM
Welcome to the forum,
You sound like another graduate of the liquid inspiration school of car repair.
Old Jul 25, 2011 | 03:06 AM
Crispy's Avatar
Hi Zeecat,
Welcome, new member myself. Curious as to what other "cookie cutter" problems have you seen? I have a 2004 XKR and noticed my conv top hydraulic fluid leaking this week. I've been afraid of using the top and getting the "green shower" that other's have posted about! Was that a tough job?
~Crispy
Old Jul 26, 2011 | 09:00 AM
Zeecat's Avatar
Default Hydraulic hose replacement
Hi Crispy,
I found Gus's webpage a great help: Auto Repair
The replacement took about 6 hours mostly since I took it slow. You'll need the top down to perform the replacement. My variation was to detach & lift the carpet in front of the drivers seat instead of removing the seat, also I left the center console installed and pushed the carpet down to access the lines. The line set is secured by snap-in retainers under the rug and near the fuse panel, it takes a little force to remove them. My daughters jag is beginning to leak so I'll be doing a repeat performance. Count on ordering the Pentosin CHF 11s fluid. You can find the parts online. The hose set is HJB8256AB. Other problems repaired: Thermostat, water pump (preventive due to the plastic impeller), serpentine belt pulleys. I did replace the inner rear wheel bearing, a front wheel bearing (special tool required), an pre-cat oxygen sensor (special snap-on socket).
Maintenance items: Trans filter and fluid change.
Your 2004 may have the metal secondary chain tensioners, mine has the second generation plastic type and will be replaced soon.
Later, Bob
Old Jul 26, 2011 | 07:20 PM
welcome to our forum zeecat
Loads going on, plenty of very friendly and helpful members as well as some excellent tech advice......all good!
In the meantime I've manually upgraded you to full forum access so you can better view the site
toronadomike
Jan 22, 2026 10:13 PM
kj07xk
Dec 18, 2025 10:56 AM
FrickenJag
Jun 16, 2025 02:15 PM
skadmiri1
Sep 9, 2015 11:27 AM
obwoodie
Sep 3, 2015 07:45 PM
