x300 4.0L rough idle
Hi to all ,
I am a new member in this forum and already I am in need of some help...by the way this is my second jaguar , one I have lost last year to expensive to repair after an accident ...unfortunnatly total los...still my favorit s-type 4,2L V8 /2003 in white color.My older XJ6/1996 4.0L sport has a rough idle.. when running in idle also a stark smell of gasoline...during driving normal usage of gas.Anybody an idea what I should do? I already changed the sparks (where champion and changed to Ngk without any improvement).
kind regards,
Patrick
kind regards,
Patrick
Hi to all ,
kind regards,
Patrick
kind regards,
Patrick
Hi Patrick
Go to the "X300" section. There are some recent topics regarding idling problems.
The raw fuel smell might be due to a misfire. Or it might be excessive fuel pressure or a number of other things.
Were the old spark plugs black with carbon?
Hi Patrick welcome aboard, good to have you here as part of the forum
You're unikley to get the help you need in this section, try checking out the relevant section for your car
Loads going on, plenty of very friendly and helpful members as well as some excellent tech advice......all good!
In the meantime I've manually upgraded you to full forum access so you can better view the site
Glad you found us, Patrick. Seems almost as many causes of poor idle as there are x300's exhibiting the issue.
Must Bea springtime thing. Plenty of help and answers in the x300 section.
patrick, did you see the post on xj6 spark plugs update, when back to oem's champions i just did a tune and use want the owner manual told me to use, runs great, but i changed other thing too like egr valve( be sure you clean all the carbon out of the 2 holes, plus i change all plug boots couple of mine were cracked ( possible arcing) I also change the 2 forward O2 sensors,backs will be a chanellge. fuel smell: check sending unit in trunk, after yrs of gas plastic fails, if u see gas dripping down ,and then into the trunk, might be your smell was mine, easy to install, just loosen lock ring install new, you have a few choices as to where you want to spend your monies.
Geno 1995 xj6 183k
Geno 1995 xj6 183k
Thank you aswell Genoaz! Today I was at the emissioncontrol and lambda was all in red ....can be a lot of things...lambda sensor...leak in the excaust system...catalysator was working fine...and also one cilinder was not doing the job it has to do,therefore the bad idle running...also now I heard during the test that also when the motor was running faster that one cilinder is not working well...so I suppose this might be one bad coil? and then we are again where to buy for a reasonable price in Europe parts?Perhaps a european member can answer me on that item?
regards,
Patrick
regards,
Patrick
Welcome. I bought a 96 xj6 4.0 with 89,000 miles about a year ago and after around a month I had rough idle problem and could smell cat converter strongly. Replaced 1 coil pack and all's been well since.
Hello and welcome to jaguarforums.com.
Hi Gus,
I checked for the car detail , and from the start I gave the car/type/year into the signature.Do not know why you do not see that...strange...I made a control and it´s there ...
regards
Patrick
regards
Patrick
We found if you post from a remote device (i-phone, Droid) it will not show in the post. Often people ask for help but fail to tell us the cars information and we are unable to provide the right feedback.
baskervillema
Oct 1, 2015 06:43 PM
