Misfire Issues
Old Dec 11, 2010 | 02:05 PM
romoan22's Avatar
Default Misfire Issues
I have a 2003 Jaguar S Type 3.0. The car stop jumping and then a check engine light came on. I just took it to Advance Auto Parts and it had 8 codes. Could anyone tell me what I need done for these codes?
P0300
P0301
P0305
P0306
P1316
P0420
P0460
P1111
Thanks in advance.
Old Dec 11, 2010 | 02:38 PM
JagV8's Avatar
Start with this thread
https://www.jaguarforums.com/forum/s...ad.php?t=46914
and look up the codes where it says, then read the possible causes.
Also, use this forum's Search for each code and see what others found.
With so many of those types, you almost certainly have an air leak. Search about that.
It will likely be the PCV hose elbow but read up and you'll see that's not the only possibility.
Old Dec 11, 2010 | 03:57 PM
bfsgross's Avatar
Yep, check for threads discussing the codes, and check the age and state of your battery's charge. A battery can start the engine with one or two weak cells whilst leaving a Jag's multitudes of electronics without enough amps and volts...resulting in a plethora of codes and warning lights.
Old Dec 11, 2010 | 10:42 PM
tdc's Avatar
tdc
P0300
P0301
P0305
P0306
P1316
P0420
P0460
P1111
Thanks in advance.
PO300 = Random/multiple Cylinder Misfire detected
PO301 = Cylinder 1 misfire detected
PO305 = Cylinder 5 misfire detected
PO306 = Cylinder 6 misfire detected
P1316 = IDM code detected
PO420 = Catalyst System Efficiency below threshold
PO460 = Fuel level sensor circuit malfunction
P1111 = IAT Sensor circuit intermittent voltage high
your welcome..
Old Dec 12, 2010 | 01:49 AM
JagV8's Avatar
your welcome..
Some of those are WRONG
You must (that's MUST) look them up as Jeff and I said in that thread I gave.
That way you get the right meaning.
You also get a list of jag's best knowledge of the possible causes.
(Wherever you looked them up - I'd never use it again.)
Old Dec 12, 2010 | 03:38 AM
tdc's Avatar
tdc
What?? !@#& me!.. OP.. Sorry.. I got them straight out of my book..
Aaahhhh… I’m going to bed..
Sorry guys..
Old Dec 12, 2010 | 03:50 AM
JagV8's Avatar
P1111 isn't even a fault code on the jag
Use that book with caution if at all.
Old Dec 12, 2010 | 05:19 AM
JOsworth's Avatar
your welcome..
P0300 - correct above
P0301 through P0306 - correct above
P0420 - Catalytic converter system
efficiency below threshold –
bank 1
P0460 - correct above
P1111 - System (OBD) checks complete
since last memory clear
P1316 - Misfire excess emission
NOTE: This DTC will flag only
when accompanied by an
individual cylinder misfire DTC:
P0300 – P0308
For the OP (romoan22)..... What exactly is "stop jumping". Please further explain any drivability issues. Also, when the light came on, was it Amber or Red? Was there any message displayed like "restricted performance", "gearbox fault", etc.? Does the light stay on, or only light while the car is "behaving badly"?
Await your reply.
Old Dec 12, 2010 | 06:33 AM
JagV8's Avatar
To the OP - just stick with post #2 in this thread to start with. You'll get more data that way.
Old Dec 12, 2010 | 08:58 AM
romoan22's Avatar
The restricted performance light comes on when the car is first crunk up but after about 5 - 10 minutes it goes off. Thanks everyone for the help.
Old Dec 14, 2010 | 05:49 AM
JOsworth's Avatar
Need more information.....
Old Dec 14, 2010 | 02:24 PM
romoan22's Avatar
Smile Now the Heat Blows Cold
The restricted performance light comes on as a warning (yellow) but after about 10 minutes of warming up, it goes off but the check engine light stays on. Now when ever I turn on the heat, it blows out cold air. Let me know what you think could be the issue now.
Old Dec 14, 2010 | 03:04 PM
JagV8's Avatar
You're giving too little data and worse have now jumped topics. We can't help if you don't put in more effort.
Old Dec 14, 2010 | 05:07 PM
Gus's Avatar
Gus
You need to stay with one problem but give us all the details related to it. This will help to define the codes http://www.gusglikas.com/images/Auto..._OBD_II_R2.pdf Looking at your codes it would not be uncommon to suggest a problem with the fuel presentation to the cylinders it could be fuel injectors or contaminated fuel and that is a guess. The P0420 suggests a problem with your Catalytic converter, H02 sensor failure or a loose connection. P0460 is fuel level sensor I think is another problem. The P1316 is related to the cylinders.
You say that the light goes out after it worms up, is this when you are driving or at idle? Did this all take place at once? When this all began did you do anything like fill the tank, work under the hood or change a part prior to this?
Not sure if you have access to do any searching or use the other applications until your probationary period is up unless you received an early access.
Old Dec 29, 2010 | 02:38 PM
JagV8's Avatar
Blinking light means catalyst damaging misfires - the serious kind.
I wouldn't mess with additives etc at all but especially not till you fix the misfires. Could be expensive to wait.
Plugs? Use the recommended ones. People may say otherwise but when chasing misfires don't mess and make things worse. You'll never fix them!
Coils give problems quite often and are a wear item due to the heat etc.
Old Feb 23, 2011 | 02:53 PM
romoan22's Avatar
What does gearbox fault mean?
Old Feb 23, 2011 | 08:02 PM
joycesjag's Avatar
There is a fault with the gearbox that the computer is telling you about. Generally brought on due to your misfiring engine problems.
Have you corrected the misfire problems yet? I would start there then worry about the gearbox (transmission) fault, again most likely to go away when the engine is repaired.
How many miles are on your vehicle?
Old Feb 23, 2011 | 09:57 PM
joycesjag's Avatar
Originally Posted by pogeeco
I just got Valve head gasket, o-ring intake gasket, spark plugs (Iridium) all replaced + oil change about 2mths ago.
I got this work done because there was and I think still is a sipping oil at the farthest left corner of the engine -if you're standing outside in front of the car.
Someone says the Iridiums are not the best plug replacement. NGK is oem or
Did you replace the IMT O-rings as well?
Read this: https://www.jaguarforums.com/forum/s...ad.php?t=49214
If there are signs of oil on the paper towel then look here: https://www.jaguarforums.com/forum/s...ad.php?t=32135
Just noticed that pogeeco posted back in Dec., with no resolution (sorry)
Old Feb 24, 2011 | 07:34 AM
romoan22's Avatar
Yeah I changed the ignition coils and the spark plugs but I still feel it jerk at certain gears. And when I come to a complete stop, the car jerks again.
