Fuel Data Computer Error
Old Sep 25, 2013 | 01:31 PM
Mikey's Avatar
Default Fuel Data Computer Error
This has been showing up intermittently for the past few days. Now it's on permanently so there's no fuel level indication on the gauge. Grrr. No codes registered, no CEL. Tried disconnecting the battery for a hard reset, no joy.
I know the battery has been thought to be the number 1 cause, is there other confirmed possibilities?
I'm sure Rick's missus hasn't been anywhere near here so that's out.
Old Sep 25, 2013 | 01:36 PM
JagV8's Avatar
MIL is about PCM and mainly emissions. You're seeing a different subsystem (mainly ICM). You'd need a jag-type tool to diagnose it but could try ETM to see if it works and if so what it shows for the fuel sender(s).
But it's probably the battery. ETM shows its voltage, too, but not sure how accurately.
Old Sep 25, 2013 | 02:45 PM
joycesjag's Avatar
Ha, are you sure about that?
Sorry Mikey I can't add anything to help you out.
Old Sep 25, 2013 | 04:00 PM
Six Rotors's Avatar
If you are coming anywhere near Whitby I will loan you my Clone JLR Mongoose set up so you can try to diagnose your problem.
On Saturday I will be at the Muttco motocross race track if that is closer for you I can bring it with me.
Old Sep 26, 2013 | 07:02 PM
Mikey's Avatar
As they say in Newfoundland- 'well oil beef hooked!'
I tried charging the battery- no difference.
Disconnected the battery, cleaned the terminals, cleaned the earth points- no difference.
I tried splicing in a known good spare battery- no difference
The plan was to head up to the car parts store tomorrow to spring for a new battery.
Thought I'd take a page from Rick's book and tried filling the fuel tank. With a rated capacity of 69.5L, I managed to put in 68.8L. Whaaaaaa? Could have sworn I had almost a half tank.............
Got in, turned the key- all back to normal.
Mark this one solved please.
Thanks for everyone's help and suggestions.
Old Sep 26, 2013 | 07:16 PM
joycesjag's Avatar
Mikey you need to switch to the "talking gas gauge" mode!
Old Sep 27, 2013 | 01:23 AM
JagV8's Avatar
Good fix!
If nearly empty, mine puts a message in message centre, warning light(s) and satnav shows filling stations. Never ran it THAT low, though!
Old Sep 27, 2013 | 07:11 AM
joycesjag's Avatar
Ohhhh Joyce has as we all know!
Old Sep 27, 2013 | 07:47 AM
JagV8's Avatar
You'd think she'd have someone to fill the car up for her as and when required
Old Sep 27, 2013 | 09:46 AM
Mikey's Avatar
Good fix!
That's what mine normally does, minus the satnav indication. There was most definitely NO message or warning light and both SWMBO and I remember a gauge indication of half a tank or so.
I wonder what happens if the float in the tank sticks- is the fuel data computer smart enough to see the discrepancy between level and calculated consumption and throws an error signal?
Old Sep 27, 2013 | 09:54 AM
JagV8's Avatar
I don't know but that error makes it looks somewhat less than smart!
Old Sep 28, 2013 | 10:56 AM
Mikey's Avatar
In thinking back and as said above, I remember the fuel gauge reading around half a tank just before the error appeared where the gauge reading went to zero. The small amount of driving I did between the fault appearing and the fill up of 68 L does not explain consumption of half a tank's worth.
For the fuel data computer to function, it needs to know rate of fuel flow, distance travelled and tank level. Tank level is required to calculate distance remaining to empty but not instant or average consumption.
If fuel flow and distance inputs are within norms but the tank level does not indicate a decrease (due to a stuck float) then the distance remaining to empty calculation would increase in value to an impossible number.
Perhaps at that point, the error message is generated and the gauge function inhibited.
Maybe Rick or others that have seen this error could chime in. One day every thing is fine, the next an error is displayed followed by an unexpectedly empty tank?
Old Sep 28, 2013 | 03:01 PM
Jayt2's Avatar
Veteran: Navy
Active Streak: 30 Days
Several years ago when I had the S-Type, I experienced something similar. The gas gauge was going from 3/4 to 3/8, back and forth, but very slowly. I wasn't driving it much at that time so I didn't catch on right away. One time when it was at 3/8, I went to a gas station and filled it up only to put 4-5 gallons in it. The "remaining distance" on the computer also showed the various mileages which differed from each gas level as shown on the gauge. OK, something wrong...
Called the dealer and made an appointment to fix it. It was the sending unit for the jet pump that was malfunctioning. They replaced that and the jet pump and all was well. Car was under warrantee at the time, otherwise $899-900 to fix it.
Don't know if this is the same as what you're going thru, but sounds similar.
Old Oct 5, 2013 | 09:45 AM
Mikey's Avatar
Thanks for the info. My car's behaviour is just getting stranger and stranger and may end up doing the same thing as yours.
As noted above, the error and non-registering gauge seemed to have been cured by simply filling the tank. I've now put about about 250 Km on the car but the gauge still indicates full or almost full (?).
The average consumption and instant consumption seem to be indicating properly as does the trip meter, but the distance remaining to empty is indicating unrealistic numbers.
The fuel gauge will waiver slightly off the full position for 10-15 minutes, but then return to full and sit there for another 10-15 minutes.
How strange.
Old Jun 21, 2017 | 07:28 PM
Jumpin' Jag Flash's Avatar
From: Pawleys Island, SC USA (formerly from Tabernacle, NJ USA)
Hey Mikey -
I was curious if you ever resolved your fuel gauge issue? If so, what was the cause and cure?
Thanks,
Steve
Old Jun 21, 2017 | 08:31 PM
motorcarman's Avatar
TWO THINGS!!!!!!!!!!!!!!!
There are TSBs related to the fault. I know that they are on the internet because I uploaded them and Gus has them on his site.
There is always 'ENGINEERING TEST MODE' for the INST PK to check the actual values of the level senders themselves.
Info for you.
bob
Old Jun 21, 2017 | 08:58 PM
joycesjag's Avatar
Bob, you wouldn't happen to know the superseded Jet and Fuel Sender part numbers by chance?
Old Jun 21, 2017 | 09:15 PM
I quit the dealer in 2006 so I only have the JEPC from what ever is available online.
I still have buddies at the dealer Parts Dept but if you call a Jaguar dealer with an OLD part number, they will see the SUPERSEDED number and advise that the OLD number is NLA.
Ask for the NEW number.
bob
Old Jun 21, 2017 | 09:21 PM
joycesjag's Avatar
Thank you. I was just trying to save a buck through eBay/Amazon. The old part numbers don't come up with anything for the sending units. Surprisingly, the harness # works.
Thanks again
Old Jun 22, 2017 | 12:59 AM
JagV8's Avatar
In ETM (Eng. Test Mode) you can rock the car and the raw fuel values should swing around.
