00 s type engine donor question
Old Jul 28, 2017 | 04:17 AM
Siebert22's Avatar
Default 00 s type engine donor question
I have an 00 4.0 and was curious if a 4.0 from a 2002 will drop in without swapping the harness/ecu...
Old Jul 28, 2017 | 09:40 AM
motorcarman's Avatar
Yes, the engines are the same BUT you will need to swap the PAS pump. The Power Assisted Steering pump/rack is different on the 2000MY (Ford Rack).
2001MY onward a ZF rack was used.
Just use the one that is in the car now.
bob
Old Jul 28, 2017 | 03:18 PM
Siebert22's Avatar
Default Thanks buddy so
bob
Thanks bud... so just take the pump off the 00 engine and put it on the 02 engine before dropping?
Also i have now timing components on my bad engine going onto the new engine I'm guessing it won't be that hard with them out... any special tips or tools needed?
Old Jul 28, 2017 | 08:14 PM
Just install the PAS pump from the old 2000MY engine to the replacement engine. Leave the hose on the pump due to the weird pipe connector. The Rack connector is normal.
The 2002MY engine MIGHT already have the newer timing components BUT I would check the engine number.
(Engine S/N 0108130000 onward)=2001, August, 13th, Midnight.
bob
