01 s-type tranny issue code# p0745..HELP!!
Old Dec 19, 2008 | 08:07 PM
Brutal's Avatar
Default RE: 01 s-type tranny issue code# p0745..HELP!!
v6 nor 8? Thermostat? or? turn on your ac the fan should be running for the raditaor, this is a on DEMAND for the fan to check operation. Don't F with coolant leaks, the back cylinders on the engine will get hot with low coolant and air pocketswithout the engine running hot and it can lead to dropped exhaust seats, and no compression. Meaning time to pull the engine apart. And useally a pressure solenoid problem is 2 fold, 1st and cheapest is FLUSH the trans, this may not fix, but sometimes it does if the solenoid is sticking, if not it need a valve body wiring harness in the trans. barring that a valve body fault, but those are the sequence of repairs I would use.
99xk8guy
May 28, 2024 09:36 PM
JarodL
Mar 7, 2024 01:39 AM
neruda
Oct 18, 2015 01:19 PM
ahunt4
Sep 14, 2015 08:17 PM
colinc1444
Sep 14, 2015 07:54 PM
