03 S-Type 3.0 Cold Rough Idle
Old Dec 14, 2016 | 01:14 PM
ShaneClara's Avatar
Default 03 S-Type 3.0 Cold Rough Idle
Morning and sitting for about 5 hours. Cold start up rough idle and loss of vacuum from brake booster. Assumed vacuum leak so I replaced the intake gaskets, quick-connect bushing assembly in intake and tested vacuum valve at the booster. All OK. Went ahead and did spark plugs while i was in there. Still no change. If this were a carburetor, I'd blame the choke for the idle problem. Typical misfire codes on all cylinders 1 thru 6. That's it, no more specific data. Drives normal and runs normal warmed up. I'd imagine if it were a vacuum leak it would be happening all of time but it isn't. Could it be the TPS or is there a specific code if it were? Thanks
Old Dec 14, 2016 | 01:42 PM
daro31's Avatar
Default Similar condition with 03 in X Type.
I went through same thing with my 3.0 X Type. I got some spray carb cleaner and sprayed it around various intake manifold areas where there are gaskets and hoses. When theengine speed changes you have found a leak. Mine was around the motor that drives the intake manifold runner length veins. Good luck.
Old Dec 14, 2016 | 01:53 PM
Gus's Avatar
Gus
Have you tested for codes?
Old Dec 14, 2016 | 02:11 PM
ShaneClara's Avatar
Misfire codes for all cylinders 1 thru 6 1316 (misfire) and 1000
Old Dec 14, 2016 | 02:34 PM
Gus's Avatar
Gus
The P1316 indicates multiple misfires and could be a number of things causing it but the first place I would be looking at is your fuel delivery. It is possible that many of your injectors are fouling. I would suggest adding a fuel treatment BG44K to your fuel and see if it clears up. I recommend it because it is the best on the market and can be found at most good repair shops. Give that a try first and see how it goes.
Link to codes. http://jagrepair.com/images/AutoRepairPhotos/P20003.PDF
Old Dec 15, 2016 | 06:02 AM
JagV8's Avatar
Reading the fuel trims will tell you if you have an air (vacuum) leak.
