2000 s-type 3.0 diagram
Old Feb 16, 2014 | 09:17 AM
Razorback31's Avatar
Default 2000 s-type 3.0 diagram
Anyone have a diagram with ( or just) part numbers) for the drivetrain, specifically the front driveshaft, the "yoke" that bolts to transmission and plastic shifter linkage that is attached to the shifter. I bought this car that had the front rubber coupling go out and broke some things. The front driveshaft isn't too bad but I don't think it's repairable.
Old Feb 17, 2014 | 09:02 AM
Ok I think I found most of the part numbers, but I can not find the socket size for the nut that holds on the yoke to the transmission, is it a special tool?
Old Feb 17, 2014 | 09:45 AM
police666's Avatar
are you sure its an s type ? it doesn't have front drive shafts.
is at an awd x type ?
Old Feb 17, 2014 | 02:27 PM
Yes it's a stype it's not a front half shaft just the front section of the driveshaft assembly. I've called dealers and they said they just use what's on the snap on and other tool trucks, just have to find the correct size socket
Andrew Fanshawe
Sep 14, 2015 07:40 PM
texaspete
Sep 10, 2015 08:34 AM
Super Cat
Sep 9, 2015 03:24 PM
stype40
Sep 9, 2015 08:14 AM
pocketrocket
Sep 3, 2015 07:44 PM
