2000 S type codes P1380 & P1383
Old Jan 28, 2008 | 07:51 PM
jag_genius's Avatar
Default RE: 2000 S type codes P1380 & P1383
if it's a V8 ,it usually isthis .passenger side cam cover has to come off and one 8 mm bolt holding the VVT solenoid in.. remove the valve and check the screen (about onecm)usually they fall to pieces and they plug the oil gallery. same with V6 but bank 1 or(a) is on the passenger side , the intake will have to be removed.. the valves i think if i can remember is $250-$300. if it's not the valve then the wiring will have to be checked.. to the PCM which is kind hard to get to.. i would start with removing the cam cover. and checking the valve screen
stanjag
Dec 29, 2024 08:26 PM
MJ'S Jag
Nov 10, 2022 08:14 AM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
nelsonht
Aug 30, 2015 06:01 AM
peterg19
Aug 28, 2015 08:42 AM
