2000 S-Type Stalling During Ilde
Old Apr 30, 2007 | 09:08 PM
Envy337's Avatar
Default RE: 2000 S-Type Stalling During Ilde
Can you head a "hissing" sound at idle (and giving it gas) with the hood up?
Old May 1, 2007 | 12:11 AM
Envy337's Avatar
You might have a major vaccum leak (hence the hissing) causing the car to stall. There are 2 breather rubber elbows that go bad and cause that. What codes did you have before?
Old May 1, 2007 | 02:15 PM
bigdreams05's Avatar
Will the car start right-up after it shuts off, or does it hesitate, or does it need a jump after it starts up?
Old May 1, 2007 | 11:11 PM
Envy337's Avatar
Did the service center scan for codes?
You did have lean codes. Lower intake gaskets????? I've never seen them replace due to leaking. Was this a Jag dealer?
Can you get part numbers for the parts they replaced, this doesnt sound right.
Old May 3, 2007 | 01:06 PM
badmojo's Avatar
I have an 03 S-type r and would like to replace the fuel filter but I'm not sure where it's located?
Old May 3, 2007 | 05:06 PM
How did you release the pressure in the fuel lines?
Old Oct 10, 2007 | 06:01 PM
Freddy2121's Avatar
Hey fellas (if u r still around). I am having the same issue. Where exactly can I find the elbows? If I need to replace them, where can I find the replacements?
I have a 2001 S-Type 3.0 88k miles
Old Oct 12, 2007 | 10:27 AM
Freddy2121's Avatar
Thanks...so does it make more sense to replace the fuel filter first? I am also getting some hesitation at normal speeds today.
