2000 S-type Sunroof
Old Oct 28, 2007 | 11:25 AM
mep's Avatar
mep
Default RE: 2000 S-type Sunroof
Can you open the sunroof all the way or does it stop before it's fully opened?
Old Oct 28, 2007 | 11:50 AM
cosworth's Avatar
Open it up in increments. Look for detrius. Remove as found. Move it back and forth looking for any odd noise indicating foreign matter. Once open, you may need to lube the sliders with some graphite or just plain old bearing grease.
I say open int all the way, clean the sliders and rails as much as possible then lube the crap out of it. See if it closes. No luck? then don't bother with a dealer, take it to a sunroof installer. They will know sunroofs WAY better than the dealer who will just order one and replace it with ZERO diagnosis. I'm more the the fix the motor, adjust the X, replace only the X camp. Where dealers replace entire units.
My Merkur when "newer" was like this. Wastegate dead? Replace ENTIRE turbo. Wastegate is 3 bolts and $100. Turbo is $1500 and 6 hours labour. Driveshaft donut chunked? $35 donut from BMW or Fiat dealer (jobber too. Ford? Replace ENITE driveshaft at $1200.
Only go to a delaer for extreme diagnostics. At worst, tow from dealer to garage for better labour rate and hand your trusted mechanic the diagnosis. Only if we the abused customer shows the dealer we are in control will our life as a Jaguar owner be easier. Never, EVER pay for or green light a swap out of a component that does not GUARANTEE a fix. Having an $800 (or worse) bill and a still non-fixed car is totally unacceptable.
Old Oct 28, 2007 | 11:58 AM
cosworth's Avatar
also have a lookie here:
http://jim.customer.netspace.net.au/...alibration.ZIP
Old Apr 28, 2008 | 08:13 PM
jag_genius's Avatar
replace assembly..
bdboyle
Sep 16, 2019 05:58 PM
donald ebanks
Sep 30, 2015 07:08 PM
Camnelson324
Sep 27, 2015 08:48 AM
zdrapec
Sep 25, 2015 05:49 AM
