2001 S-Type starts then stops
hi folks
have done some basic checks all ok with spark at the plugs,fuel pump is fine. when i removed throttle body sensor with help i can start the car by holding the butterfly an runs fine. so i checked power to throttle body motor dead. went back to relay also dead. changed relays nothing. so theirs no power to the relay. is it fused? where to go from here!!!!!!!!!
Welcome to the forum boomerang,
I've moved your question from UK & Eire Region to X350 forum. Members here with the same model will be able to help.
How long does the car run until it shuts down? The attached is a oneline for your car I hope it helps.
Link http://jagrepair.com/images/AutoRepa...x2022001en.pdf
Careful with that throttle body - precision part and can take a finger off, plus PCM expects to be in charge.
Still, good diagnosis so far
I'm surprised you don't have the MIL on and codes - or do you?
kenneyk843
Nov 12, 2021 07:50 AM
