2002 S Type Fuel Pump
Old Jun 29, 2014 | 03:21 PM
artveiga's Avatar
Default 2002 S Type Fuel Pump
Need to buy a new Fuel Pump. I would like a recommendation as to which one woul be a good choice.. Thanks! for any responses
Old Jun 29, 2014 | 09:24 PM
abonano's Avatar
personally, I would settle for an OEM replacement fuel pump ($400 - $500). They now have pumps ($80 - $100) you can splice your fuel line into, bypassing the failed pump (not a fan of that option though) but is a much cheaper option. Or, on that same cost field ($80 - $140) you can get a used fuel pump assembly from a donor car.
Have you tested all associated fuses, relay and inertia switch? What about the fuel filter - did you change it?
Sometimes you may be lucky - if all was checked off than yes, a new fuel pump is in order.
Old Jun 29, 2014 | 11:13 PM
artveiga's Avatar
Hi! Thanks for your quick response! Yes all fuses and inertia SW. OK, Didn't check fuel filter or relay, this car has 11,000 miles on it. It sits a lot. The pump went out while the car was still under waranty, about 4,000 miles on it at that time.
fast40driver
Apr 19, 2024 07:24 AM
h4wk
Nov 27, 2015 05:10 PM
convincor
Sep 3, 2015 08:03 PM
bluerdg
Sep 1, 2015 08:07 AM
BigD
Aug 31, 2015 06:13 AM
