2003 Jag STR ethanol compatible?
Old Apr 24, 2020 | 03:41 PM
discuspro's Avatar
Default 2003 Jag STR ethanol compatible?
Anyone know if fuel component, injectors, etc. were made to be compatible with ethanol mix gasoline? Starting to wonder about what I may need to start changing if this isn't the case, to prevent a complete systems meltdown.
Old Apr 24, 2020 | 04:12 PM
JagV8's Avatar
E5 is definitely OK (quite hard to avoid it over here). E10 I think is also OK. Don't go beyond those.
You may need to expect lower performance as it doesn't really want them.
Old Apr 24, 2020 | 04:25 PM
discuspro's Avatar
Ok. I wasn't worried so much about performance but rather some kind of eventual fuel line replacement, injector, engine tear down, rubber seals....which for an STR is an "um not gonna", even for a gearhead like myself.
Old Apr 24, 2020 | 09:11 PM
Doug's Avatar
Jags have been E10 compatible for a long, long time. The owners manual for my 1985 Jagsays it's OK E10. In my part of the country E10 has been standard issue for 20+ years; I've had no problems
Jason Souhrada
Mar 22, 2020 02:05 PM
MeanAzKitty
64
Jan 16, 2015 12:51 AM
HushmoSTR 2003jag
Nov 15, 2014 01:37 AM
clubairth1
Nov 5, 2011 07:08 AM
phd12volt
28
Oct 23, 2011 12:09 AM
