2003 jaguar s-type
Old Jul 16, 2018 | 11:55 PM
princesscha's Avatar
Default 2003 jaguar s-type
My engine light and display performance restriction came on, the mechanic said, cylinder 5 is backfiring, how can this problem be fixed without investing a lot of money? Unfortunately, I'm between jobs and unable to get it repaired properly.
Old Jul 17, 2018 | 12:04 AM
Datsports's Avatar
back firing or miss firing ?
back firing on one cylinder is unusual .
miss firing is more common .
DIY is the only way to fix on the cheep .
you could start by removing the coil and checking for oil in the plug well .
and remove the spark plug and inspecting it also . and swap coils around to see if the issue shifts with the coil .
Old Jul 17, 2018 | 02:47 PM
scottjh9's Avatar
if it ends up being a coil I have 7 extras and would gladly give you one...I changed mine out because I had 1 bad one and replaced them all and saved the good ones....just need the part number to match...I live in ca also so mailing would be cheap...
Old Jul 17, 2018 | 03:52 PM
S-Type Owner's Avatar
Is your S-type a v8 or a V6 ? The coils are not the same for both engines.
JR
JimC64
Sep 22, 2025 02:52 PM
SteveM
Motorsports
103
Oct 19, 2024 02:58 PM
Jul 31, 2012 01:29 PM
sjuraud
Aug 28, 2010 02:11 PM
Dec 2, 2005 12:57 AM
