2003 lean bank 1,2 codes restricted performance light
Old May 2, 2019 | 05:47 AM
Mike 8897's Avatar
Default 2003 lean bank 1,2 codes restricted performance light
I have a vacuum leak on passanger side behind supercharger . Smoke test shows small amount of smoke in that area . Can't see we're it's comming from. Tried spraying with no luck. Any suggestions where this vac leak could be comming from . Been an on going problem I'm about to tear down top end and replace everything myself,
Old Aug 24, 2019 | 12:32 AM
Aarcuda's Avatar
How do u do a smoke test
Old Aug 24, 2019 | 04:17 AM
Datsports's Avatar
99% of the time it’s the brake booster vacuum port on the right side of the intake elbow below the bypass diaphragm.
Old Aug 24, 2019 | 07:10 PM
clubairth1's Avatar
Community Influencer
Yes that is a prime suspect!
Look here for a very in depth repair.
Brake Booster Leak
Volbrewer
Jun 18, 2018 06:37 PM
n2audio
May 30, 2017 09:33 AM
jazzwineman
May 29, 2017 09:44 AM
user 652867429824
Nov 5, 2016 07:54 PM
mjlaris
Jul 7, 2014 03:32 PM
