2003 Lincoln LS V8 with Jaguar engine question
Old Oct 15, 2016 | 08:57 PM
03linls's Avatar
I did put a new and expensive charcoal cabin air filter in the car and it did nothing for the fumes. Going to take it to one more recommended mechanic before I say that I'm just going to live with it. I'll keep you posted. Thanks again for the help.
Old Oct 15, 2016 | 10:21 PM
Mikey's Avatar
Originally Posted by Mikey
Start the engine from cold with the hood open. Is the smell from that end of the car?
You never answered this.
Originally Posted by 03linls
Thanks, but I guess my question is that even the best filter out there would not keep what I'm smelling the first 2 minutes or so of driving out of the cabin? Is that correct?
Correct. Smelly HVAC (referenced in my first post) that's only noticeable when the system is initially turned on would be bacteria or mould on the evaporator. Only noticeable inside the car also.
Not sure why you changed the HVAC filter.
Old Oct 17, 2016 | 02:47 PM
03linls's Avatar
Thanks. It was dirty so I changed it. Also, I thought I should eliminate everything before I take it back in to the other mechanic.
Plus, I read this: "Not correct, if marketing information is to be believed, anyway. I don't think I'm disagreeing with Mikey, per se. IF the fumes are originating in the engine bay, say exhaust leak, or oil dripping on the hot bits or what have you, and IF you have a properly-installed, quality activated charcoal HVAC filter, and IF your plenum seals aren't knackered, THEN you should not be getting doused with sensible fumes in the cabin on startup."
I thought maybe, just maybe, a dirty filter, a cheap filter, or no filter at all could allow what I'm smelling in. Not the case.
I did start it up and did not smell anything that I am smelling inside the cabin when the hood was up. Just baffling...
Thanks for the continued help.
Old Oct 17, 2016 | 04:22 PM
Mikey's Avatar
This points back to contaminated HVAC system. There are sprays available that will kill the mould.
https://www.amazon.ca/Interdynamics-.../dp/B000UHD74E
Old Oct 17, 2016 | 04:39 PM
03linls's Avatar
Thank you. Great suggestion. In your opinion, does it still point back to contamination if the smell is gone after a minute or so and only on a very cold start?
Old Oct 17, 2016 | 06:06 PM
Mikey's Avatar
Yes and yes. I had this very condition on a former car.
Old Oct 17, 2016 | 08:35 PM
03linls's Avatar
Was the odor that you were trying to remove musty or something else? I feel like mine is exhaust but this is definitely worth a shot.
Thank you for the suggestion.
Old Oct 17, 2016 | 09:09 PM
  #28
Mikey's Avatar
Musty. moldy, stinky runners.
Old Oct 19, 2016 | 01:05 PM
03linls's Avatar
I tried the HVAC cleansing...smells nice and lemony but at first start up, I still
smell the exhaust/oily odor.
Old Oct 19, 2016 | 02:13 PM
  #30
JagV8's Avatar
Still sounds like (say) oil drip onto exhaust.
Old Oct 19, 2016 | 04:06 PM
  #31
Mikey's Avatar
That should be noticeable outside the car and would only be present after the exhaust has warmed a bit, not immediately after engine start.
Old Oct 19, 2016 | 04:19 PM
  #32
JagV8's Avatar
Ok. I thought if it seeped out overnight it could be there ready to create the smell.
RSpi
Mar 31, 2017 10:48 PM
03linls
Sep 19, 2016 06:30 PM
BLKHWK
Jul 28, 2016 11:37 AM
SirJag
Feb 7, 2016 02:57 AM
ryandunton
Mar 3, 2012 08:43 PM
