2003 S-type 3.0 dies at startup and no codes???
Old Jul 2, 2010 | 12:49 PM
JagV8's Avatar
Ignore your code scanner for any P1 code. Look the code up using google (if not here) using:
jaguar code P1000
(or whatever P1xxx)
The shaking may be a biggish air (vacuum) leak. Gurgling tranny - better hope not!!
Lots of faults are so serious (or transient - probably not this one, though) they cannot set a code readable by a cheap/generic scanner or simply cannot set a code at all.
Mafioso's Avatar
air filter service? perhaps they damaged the MAF?
Old Jul 2, 2010 | 12:51 PM
JagV8's Avatar
I forgot to say: Search will help you about the usual causes & fixes of leaks.
Also try a Search on idle
(because yours won't)
Old Jul 2, 2010 | 03:49 PM
JOsworth's Avatar
Air leak sounds like the most likely culprit. I would also check for proper fuel pressure (gurgling noise???). Could be a bad line...
Oh, BTW, "*******" is not a wise term to use on this particular forum.. Just so you are aware, some of the best advise comes from those members that are also employed at a dealership..
SD96XJ6L
Jan 12, 2022 04:30 AM
Adam Lueb
Sep 28, 2015 02:54 PM
ccfulton
Sep 20, 2015 05:15 PM
OkieTim
Sep 8, 2015 04:48 PM
OkieTim
Sep 2, 2015 12:48 PM
