2003 S-Type 4.2L Starter Does Not Crank
Hi all,
Couldn't find this on the forums so here goes...Working through a starter does not crank procedure in the 1999-2003_S-Type_FSM, Section 303-06, Page 2896 , A: The Engine Does Not Crank, and wanted to know if someone can explain A6 : Check the Permanent Live Voltage to Starter Relay. I said NO to the question, so the procedure says to REPAIR starter relay permanent live supply circuit. HOW do I do that, is there a diagram or anything that says how? Thanks for all the past help...
The schematic diagram of the wiring is available from this forum.
It may be helpful if you post details on the vehicle and what has been done thus far and what other details may be helpful, ie PATS...
1964Daimler
Sep 9, 2015 11:28 AM
