2003 s type R fuel pump problems
Old Apr 29, 2025 | 10:22 PM
strneto's Avatar
Default 2003 s type R fuel pump problems
just picked up a 2003 jaguar str im new to jaguars car cranks but does not start haven’t checked none of the fuses but im thinking it might be the fuel pump since the car has been sitting for 2 years cant find any threads on fuel pumps for a STR does someone know where i can buy a fuel pump for the str?
Old Apr 29, 2025 | 11:43 PM
NBCat's Avatar
The X202 supercharged vehicles use two fuel pumps:
https://www.sngbarratt.com/English/#...assembly/31438
Use a smart phone to connect to the vehicle's ECM/PCM via the OBD port with a Bluetooth interface and the Torque app to read the fuel pressure. There should be roughly 3 bar of pressure with the ignition in the ON position prior to engaging the starter motor.
Old Apr 30, 2025 | 08:24 AM
kr98664's Avatar
Welcome to the forum.
A little history of your new car will be very helpful before jumping straight to condemning the fuel pumps. Was this somebody's reliable daily driver and this is a new problem out of the blue? Was this a derelict project dragged out of a field and this is the first start attempt in years? Something in between?
Before entering FullPanicMode™, check the the security system in case it entered theft protection mode. Watch the red LED on top of the dash to see if any codes are stored. Here's how the light is supposed to behave if all is good and no faults are present:
First, lock the car with the key fob. Press the lock button a second time to set the alarm system. The horn should chirp once. Watch the little red light. It should flash once every few seconds or so to show the system is armed. Now press the key fob unlock button twice to unlock all the doors. The red light should go out. Now hop in the driver's seat and turn the key to RUN (Not start yet). The red light should come on solid ONCE for about 3 seconds and then go out. If it flashes anything after that, you've got a stored fault and the security system may have inhibited the fuel injectors.
Old Apr 30, 2025 | 09:49 AM
strneto's Avatar
well i don’t know much about the history of the car just know it ran before it was parked hasn’t been started in 2 years has 130k miles, car cranked once but didn’t want to crank again im pretty sure its bc of the battery since one of the cells is bad. i’m just thinking it might be the fuel pump because the pump didnt prime. i will be checking the security features, does anyone know if the 4.2l v8 fuel pump fit in the STR or where can i buy the fuel pump for a STR if needed.
thanks.
Old Apr 30, 2025 | 10:03 AM
clubairth1's Avatar
Community Influencer
No the STR needs the pumps NBCat listed above.
Old Apr 30, 2025 | 10:18 AM
NBCat's Avatar
Originally Posted by strneto
... does anyone know if the 4.2l v8 fuel pump fit in the STR or where can i buy the fuel pump for a STR if needed.
thanks.
See post #2 above.
Old Apr 30, 2025 | 10:23 AM
strneto's Avatar
it says the fuel pump is unavailable- no longer manufactured
Old Apr 30, 2025 | 10:40 AM
NBCat's Avatar
Have you considered contacting SNG Barratt directly?
As posted earlier, the X202 supercharged vehicles use two fuel pumps. The one on the left of the vehicle is to pump fuel to the main pump on the right side of the 'saddle' tank.
What is the fuel pressure with the ignition in the ON position prior to engaging the starter?
Here is a link to the listing for the fuel pumps on Rock Auto:
https://www.rockauto.com/en/catalog/...assembly,10147
Old Apr 30, 2025 | 11:02 AM
kr98664's Avatar
im pretty sure its bc of the battery since one of the cells is bad...
Has the battery been replaced yet? You mentioned being new to the world of Jaguar. These cars are VERY sensitive to low prestart voltage. You'll wind up with all sorts of spurious faults. If you have not done so already, replace that poor battery and save yourself a LOT of grief.
Make sure the replacement is fully charged, too. Most batteries are not fully charged in the store, and you can't count on the alternator to do the job properly.
Old Apr 30, 2025 | 11:25 AM
strneto's Avatar
okay thanks will order the fuel pump just to replace it since it’s been sitting ,right fuel pump on rock auto is out of stock so just will be ordering the left one for now.
strneto's Avatar
yes i will make sure to buy a new battery when i get a chance bc the car isn’t cranking anymore
Old Apr 30, 2025 | 01:46 PM
NBCat's Avatar
...right fuel pump on rock auto is out of stock so just will be ordering the left one for now.
If you look at the listing, Rock Auto claim the pump fits left and right positions.
The one for the left is a siphon pump, which doesn't work for the X202 with the supercharged engine.
Old Apr 30, 2025 | 03:43 PM
strneto's Avatar
oh okay i see that so it should fit left and right sides
9mm
25
Jul 2, 2023 10:22 AM
Erik1995
Jul 2, 2023 01:49 AM
Hotshoe
Dec 19, 2014 09:02 PM
03Xtype
Dec 2, 2012 05:05 PM
