2003 S-Type Valve Cover Torque Specs
Old Jan 14, 2016 | 10:30 AM
mophoto's Avatar
Default 2003 S-Type Valve Cover Torque Specs
I have the issue with oil collecting in the spark plugs causing hesitation and code P1316 in my 2003 S-Type with 6 cylinder 3.0 engine. This seems to be a common issue. It started a burning smell one year and 25,000 miles after replacing all coils and spark plugs for similar engine faults. Now, with 106,000 miles total, I am replacing the valve cover gaskets as well as the upper and lower intake gaskets.
I have not been able to find the torque specifications and torque sequence for this vehicle. Can anyone please post this information?
Thanks,
Maurice
Old Jan 14, 2016 | 02:43 PM
tbird6's Avatar
Yes it is in the shop manual. Jaguar calls it the JTIS.
It's a free download on this forum.
Details on Win7 64 bit new install method & new JTIS21 S-Type archive ( 1 2)
Old Jan 14, 2016 | 02:51 PM
Welcome to the forum Maurice,
I've moved your question from General Tech Help to S-Type forum. Members here with the same model will be able to help.
Old Jan 14, 2016 | 04:06 PM
joycesjag's Avatar
Don't forget to replace your IMT o-rings while you are at it!
Old Jan 14, 2016 | 07:42 PM
mophoto's Avatar
Thanks for the help. Much easier with the proper information. I did buy Fel-Pro gasket kits for both the valve covers and for the intake manifold. The upper intake manifold came with the o-rings for the IMT. Hopefully the valve cover gasket will not be a problem. The one that I removed had full coverage around the valve cover bolt holes. The Fel-Pro gasket doesn't (covers only one side of bolt, some inside and some outside).
alexschmidt
19
Dec 30, 2015 06:36 AM
XKR8
Dec 22, 2015 05:16 PM
sklimii
Dec 20, 2015 10:39 AM
Carfar_Farcar
Dec 17, 2015 12:15 AM
davecabezo
Dec 16, 2015 08:28 PM
