2003 STR Shifts into Reverse Slowly
Old Sep 19, 2016 | 09:23 AM
mit2700's Avatar
Default 2003 STR Shifts into Reverse Slowly
Hello, I searched and found info about the older model S Type's with the Ford transmission having this problem, but had no luck with finding posts about the ZF gearbox shifting slowly into Reverse.
Can I use the same procedure to fix this? It takes a few seconds to go from Drive/Park to reverse. Or is there something else wrong possibly?
Thanks!
Old Sep 20, 2016 | 11:55 AM
JagV8's Avatar
It's so different I think I'd ignore the Ford box. I'd start by checking the 2 bolts are not loose or missing that hold the shift cable to the trans side.
After that it's the fluid level / replace fluid.
Old Sep 20, 2016 | 12:03 PM
clubairth1's Avatar
Community Influencer
Have you checked the fluid level? It's not real easy.
Start there first as JagV8 said.
Pantera928
Mar 1, 2017 05:40 PM
Dukecharlemagne
Sep 7, 2016 03:10 AM
Havafalcon
Sep 7, 2016 01:36 AM
phanc60844
Sep 5, 2016 01:28 PM
MK2
Aug 23, 2016 06:06 AM
