2004 Jaguar S-type base windshield washer pump
Old Mar 5, 2014 | 03:37 PM
MarcN's Avatar
Default 2004 Jaguar S-type base windshield washer pump
there are many pumps windshield washer pump which one is the good one for 2004 Jaguar S-type base. do you have a diagram and instruction on how to mount it
Old Mar 5, 2014 | 05:26 PM
tbird6's Avatar
Why don't you use the one Jaguar installed in the factory?
Old Mar 7, 2014 | 03:12 PM
MarcN's Avatar
Default thanks
Hi thanks for your response but it does not help to much to solve my issue. I know I could use the factory, it is really expensive, this is why I was asking if anyone knew about similar pumps
Old Mar 7, 2014 | 04:17 PM
JagV8's Avatar
Your orig post so terse no1 understood
Result as above
Old Mar 7, 2014 | 05:30 PM
sjgh's Avatar
I would download JTIS from the stickies (has diagrams in there as well). These are the text of the instructions -
Windshield Washer Pump
Remove the radiator splash shield.
Disconnect the windshield washer pump supply hose.
Disconnect the windshield washer pump electrical connector.
Remove the windshield washer pump.
Just get a pump thats exact fit.
Old Mar 7, 2014 | 05:56 PM
joycesjag's Avatar
Man, JTIS makes it sound like a 5 minute job as described above, don't be fooled.
Are you sure the line(s) are clogged?
stanjag
Dec 29, 2024 08:26 PM
Isoruku
Jun 19, 2020 12:54 PM
ControlIssues
Sep 3, 2015 07:38 PM
EastFalk
Aug 29, 2015 08:22 PM
NinoGrimace
Aug 26, 2015 05:15 AM
