2004 S Type climate control goes from a/c to heat
Old Jan 22, 2012 | 10:11 AM
magoo6610's Avatar
Default 2004 S Type climate control goes from a/c to heat
On our 2004 S Type while in auto mode and the temps set at 70 degrees the system goes from blowing nice cold air to heat ll by itself and the only way I can keep it blowing cold is if I set the temp all the way to low. My question also is how many interior temp sensors are there??
Old Jan 22, 2012 | 10:53 AM
There's four one on the passenger side and two on the drivers side going into the ac/heater unit and one behind the little grille above the ignition switch.
Old Jan 23, 2012 | 09:24 AM
magoo6610's Avatar
Default 2004 s type climate control problems
Okay I have cleaned those and still have the problem with it changing from cold to heat at anytime what could be the problem. Help ???
Old Jan 23, 2012 | 01:03 PM
tbird6's Avatar
You need to search some here. You have a very common problem and you will soon find out the most likely cause.
ClassiXtype
Oct 22, 2023 05:29 AM
Aranon
Sep 1, 2015 01:00 PM
GreyXK
Aug 31, 2015 05:15 PM
EastFalk
Aug 29, 2015 08:22 PM
smokin_hobo
Aug 29, 2015 12:13 AM
