2005 S-Type 4.2: Water Pump needs replacing, what else should I get done
Old Sep 15, 2012 | 02:45 PM
jmcGoBlue's Avatar
Default 2005 S-Type 4.2: Water Pump needs replacing, what else should I get done
Hey Folks,
Still loving the S-Type 18 months after purchase, but now I have a water pump leak. Along with ordering a new pump, I got a new lower radiator hose and thermostat...just figuring that I might as well get them all done while the water pump is being replaced.
Question is, is there anything else I should go ahead and get done at the same time, to save future trips to the shop? (Note, the car now has 115k on it, I can't figure out how to change the Sig...) I was thinking that maybe I should get all the belts and tensioners changed as well, but I honestly don't know if it's worth the additional cost. Any advice would be appreciated, as always!
Old Sep 15, 2012 | 09:36 PM
clubairth1's Avatar
Community Influencer
I think if you have the NA 4.2L you can get an Aluminum thermostat housing to replace the crappy factory plastic. Not many water pumps reported leaking but a lot from the plastic cooling parts in that area. So be prepared for something to break when you take it apart.
Your top tank or degas bottle is usually replaced before 100K miles? Is yours still original? It's on top so you can change it anytime really.
Yes change the serpentine belts. You have the latest and best timing tensioner set up. No need to worry.
The main thing is have the plugs and possibly the coils and cam cover gasket been changed? Only the plugs are called for but the others should be considered wear items too.
Of course the famous DCCV should also have been replaced by this time and possibly the AUX coolant pump along with the attaching hoses.
You did not ask but have you serviced the transmission?
Old Sep 15, 2012 | 10:31 PM
bfsgross's Avatar
Welcome Jason. clubairth basically covered most of the common preventative and premature wear items. You're thinking on the correct path by performing basic swap in whilst in there anyway kind of logic.
Old Sep 15, 2012 | 11:07 PM
jmcGoBlue's Avatar
Thanks for the info. Yeah, I did have the plugs replaced when I bought the car (at about 100k)...didn't change the coils at the time because they weren't giving any problems (and for some reason I remember them being a lot more expensive 18 months ago). I thought about getting those done now since I can get a complete set for under $100, but since they aren't giving any problems I'll probably just wait a while so I have reason to do the plugs again at the same time. DCCV has been my only significant issue with the car, and had it replaced soon after taking ownership. Regarding the transmission, I did develop the "squawk" starting a couple months ago, so I'll be getting that serviced as well.
Regarding the serpentine belts, are you saying that I should just leave the current tensioners in place and only change the belts?
Old Sep 16, 2012 | 08:40 AM
clubairth1's Avatar
Yes. Forget the tensioners for the timing chains. It's no longer a problem for your year car.
Have you flushed the brake fluid and changed the coolant? Don't forget the cabin filter and gas filter both are hidden and out of sight.
Glad to hear the DCCV has been changed as if left bad it can take out the climate control unit. We do have a repair for that but avoiding it is the best.
stanjag
Dec 29, 2024 08:26 PM
fast40driver
Apr 19, 2024 07:24 AM
Xj812
Oct 26, 2015 05:04 AM
celticpiping
Sep 18, 2015 06:17 PM
dpappyp
Aug 27, 2015 06:31 AM
