2005 S-Type R Coolant Demonic Possesion
Old Feb 9, 2011 | 10:33 PM
wilecoyote's Avatar
Originally Posted by wilecoyote
It was last filled in October. A coworker and I were thinking maybe some buildup got stuck in the radiator. I replaced the reservoir a couple of years ago so I think I am ok there. I'll put it on jacks tomorrow and poke around. The roads were icy today and my PS2's won't work on that! I drove, err slid to work in here car today.
Today was the first time I've driven since I smelled the coolant. I took maybe a half a cup out the day I smelled it. I noticed no problems at all. The car warmed up a bit slower than usual but it was in the low 30's! No coolant smell at all and I made sure that the recirculate air was off. I can't explain it and I hate mysteries. I'm certain that something is hinky. I couldn't find anything; let's hope if I do I'm not on an interstate. I'll be popping the hood at every stop.
Old Feb 10, 2011 | 09:17 AM
richard wood's Avatar
Our '05 S-Type 4.2 had a slight leak at the vent line connection on the reservoir that did not show itself unless I moved it slightly allowing a visible stream of steam to escape. The first indication was the low coolant message. Ultimately, I did see some orange residue below the connection, which prompted me to start probing. The hose is fairly soft and the hose clamp was just beginning to lose its grip.
Old Feb 10, 2011 | 09:42 AM
Brutal's Avatar
Originally Posted by richard wood
our '05 s-type 4.2 had a slight leak at the vent line connection on the reservoir that did not show itself unless i moved it slightly allowing a visible stream of steam to escape. The first indication was the low coolant message. Ultimately, i did see some orange residue below the connection, which prompted me to start probing. The hose is fairly soft and the hose clamp was just beginning to lose its grip.
you need to really watch this cause that is right where the reservoir cracks. That line breaks off and pumps coolant out while driving, of course if you keep a small pair of vise grips in the trunk you can clamp off this hose from the engine without issue and get home and fix later, but left off and you wont get far
Old Feb 12, 2011 | 08:24 AM
Staatsof's Avatar
Default Dealer finds nada
So I had the car in yesterday for the RH headlamp repair (sagging ****).
I also asked them to look for the leak. I am losing coolant.
They found nothing. Again. They said they washed everything off while they had the belly pan and bumper facia off for the headlamp repair.
I get home and after an hour's drive it stinks of hot coolant.
I guess I'm going to have to fix this or at least find it for them.
Apparently this is going to be one of those frustrating chase it almost forever issues.
caveforce
38
Nov 16, 2015 10:19 AM
CaneCounsel007
Nov 13, 2015 09:05 PM
captbob73
Oct 24, 2015 05:49 PM
KarimPA
Sep 12, 2015 08:15 AM
KarimPA
Sep 3, 2015 07:32 PM
