2005 STR P0308 Cylinder 8 Misfire
Old May 22, 2022 | 08:03 PM
BrianGilman's Avatar
Default 2005 STR P0308 Cylinder 8 Misfire
Is there a common cause for code P0308? I’ve searched and found mostly issues with V6 and non supercharged S-Types.
I replaced the coils and plugs a couple months ago. The only other recent change is a Banshee Screamer intake. I can’t imagine the intake is the cause. Maybe I damaged a vacuum line in the process of installing it? I’m going to swap coils with another cylinder to start.
Is there something super common that I should look towards first?
Old May 22, 2022 | 11:37 PM
kr98664's Avatar
Swapping the suspect coil with a known-good unit from another cylinder is a good first step in troubleshooting.
What brand coil did you install? Some no-name specials and discount chain house brands have been known to cause trouble right out of the box.
Old May 25, 2022 | 05:03 PM
I replaced the coil and I’m still getting the misfire. It’s a definite low RPM, light throttle “miss” or skip.
Old May 25, 2022 | 10:45 PM
kr98664's Avatar
I replaced the coil and I’m still getting the misfire...
Still getting P0308 for #8 cylinder? Or did the code follow the suspect coil?
Old May 26, 2022 | 02:27 AM
JagV8's Avatar
If replaced with a new one, swap with another in case new is bad.
Old May 27, 2022 | 04:21 AM
M-e-l-l-o-w's Avatar
As above, did the code follow the faulty coil?
Mellow
Old May 27, 2022 | 08:12 AM
S-Type Owner's Avatar
"Is there a common cause for code P0308? I’ve searched and found mostly issues with V6 and non supercharged S-Types." Cylinder eight misfire on a V-6, now that is a really tricky one to diagnose...
Old May 28, 2022 | 01:05 PM
Yes the most common cause is a faulty coil pack!
Mellow
Old May 29, 2022 | 11:00 AM
Ok...ok...wise guy...lol. Most of the misfire threads I've found are for the V6. I replaced the #8 coil with a new one. It still gave a P0308 code, but it took days for it to show up. I cleared the code and it hasn't come back yet, but I can feel feel an intermittent "skip" or "miss" at low speed, light throttle cruising. It makes me think that it's either the fuel injector or a vacuum leak. It doesn't seem effected at heavy throttle.
I've been planning on rebuilding the supercharger and putting a 6% pulley on it, so I guess I'll replace all the vacuum lines and having the injectors reconditioned while the blower is out.
Old May 30, 2022 | 07:56 AM
A vacuum leak is likely to impact more than a single cylinder, no? That suggests an injector as the next possible culprit. Good, plan...
Old May 31, 2022 | 06:34 AM
Sportston's Avatar
Could be an injector, but inlet manifold gasket leak is possible too. Try to see if there are any vacuum pipes coming from that branch of the manifold. If there are any, check them for leaks but also check their destination. Example: on some cars the vacuum pipe for the brake servo comes from one end of the manifold. If the brake servo leaks it induces a lean mixture on one cylinder (this is only general advice. I don't know if the V8 has this or not).
Old May 31, 2022 | 07:46 AM
JagV8's Avatar
Check fuel trims. Any leak will show there.
Extinct
16
Nov 24, 2023 01:27 PM
slmskrs
Oct 27, 2015 11:47 PM
DiaCero
Feb 13, 2014 09:20 PM
carlorner
Jul 11, 2011 06:54 AM
carlorner
Jul 6, 2011 05:31 PM
