2006 S-type rear brake caliper rebuild
Old Oct 16, 2016 | 07:57 PM
Geezer's Avatar
Default 2006 S-type rear brake caliper rebuild
Does anyone have directions on how to get the get the ebrake lever out of the rear brake caliper. Im in the process of rebuilding my rear brake calipers and one was leaking around the ebrake lever shaft. Thanks
Old Oct 17, 2016 | 09:12 AM
clubairth1's Avatar
Community Influencer
Yes. It's in the shop manual the JTIS.
Lucky for you this is free and available at the top of this forum. Look for JTIS in the title. They have it setup as a very easy install.
If you still have problems you can get a PDF version on EBay for around $10. You really need some repair info on your car!
It will be worth it for sure.
Old Oct 17, 2016 | 01:02 PM
Geezer's Avatar
I do have the workshop manual, I must have missed that bit. Ill look again
Old Oct 17, 2016 | 06:19 PM
Geezer's Avatar
Nope. stripping the caliper down to replace the caliper EPB shaft seal isn't in the workshop manual or at least the factory manual I have.
Lawrence
XJ40 ( XJ81 )
17
Oct 31, 2016 12:20 PM
NebRuss
XJ40 ( XJ81 )
Oct 21, 2016 03:03 PM
Thang Nguyen
Oct 1, 2016 11:34 AM
stuart goodwin
Sep 28, 2016 11:14 AM
06-XJR
Sep 19, 2016 07:47 PM
