2006 S-Type v8 Fuel Rail Pressure Sensor Part#
Old May 25, 2024 | 11:50 AM
ampiko's Avatar
Default 2006 S-Type v8 Fuel Rail Pressure Sensor Part#
Hello,.
Would this FPS OEM# AJ87977 also fit the 2006 year ? In some websites it says that it only fits upto vin N52xx. My v8 S-Type vin ends in N54xx. Thanks
Old May 26, 2024 | 09:07 AM
clubairth1's Avatar
Community Influencer
Best to use a factory jaguar parts site and check it against your VIN.
I have used these guys;
Harper Jaguar
Old May 26, 2024 | 10:53 AM
ampiko's Avatar
Thanks, I also use them. In fact the info in their website raised this question. I think they had only two model/years listed under Fitment, causing it make the AJ87977 incompatible ?
https://parts.harperjaguar.com/oem-p...ulator-aj87977
Later I found other sites listing many years and models which are compatible
Old May 27, 2024 | 10:16 AM
clubairth1's Avatar
When I run into this kind of stuff I send an E-mail to the parts department asking which part is correct.
I checked JEPC and it does not show a different sensor and lists only the part number you posted.
But I also found the dealer listings said it did not fit like you said but again no other part number was suggested?
Old May 30, 2024 | 02:50 PM
ampiko's Avatar
I am having a tough time to confirm the use of NTk-FPC011 / AJ87977 / Ford #3R3E-9F972-AA / 3R3E-9F972-AB. Many sites say that these fit only upto 2004 for N.A S-type V8. S/C models are fine all the way
Has anyone used it on a 2006+ v8 N.A S-Type? Thanks
Allan01
Dec 12, 2021 01:06 PM
Sixx Dogg
Aug 9, 2015 10:56 AM
steven7413
Oct 6, 2009 02:41 PM
thisguy
Apr 22, 2008 05:49 AM
