5R55N autobox delay in selecting Drive
Old Sep 13, 2018 | 06:01 PM
NBCat's Avatar
It is possible there is a pressure issue with the pump. Did you check the line pressure?
When the gearbox is engaged, the pressure should rise to between 7.6 and 18.1 bar (110 and 263 PSI) in Drive and to between 9.7 and 24.1 bar (140 and 350 PSI) in Reverse.
Old Sep 14, 2018 | 06:05 AM
wheelerc's Avatar
I didn't check the pressure (I don't have the tools/knowledge to do that). Am I right in saying if the pressure is low the box will need to come out to check the pump and replace the pressure control valve?
Old Sep 14, 2018 | 08:57 AM
NBCat's Avatar
If the pump is faulty, the gearbox must be removed to change it. The pressure can be checked with the gearbox in situ as the fittings for line and control pressures are on the sides.
Old Sep 14, 2018 | 09:04 AM
wheelerc's Avatar
Thanks, is there a guide somewhere on how to do this for an amateur like me?
I can see where the fittings are from the manual you linked to previously, and the pressure range, but I'm not sure what equipment I'd need and how to connect/test...
Old Sep 14, 2018 | 09:12 AM
NBCat's Avatar
Here's one for thirty quid:
https://www.ebay.co.uk/itm/Automatic...QAAOSwGMFbcpGA
The correct thread connector must be fitted to the gearbox and then install the gauge. Probably best to have one of your mates handy to start/stop the engine.
Old Sep 14, 2018 | 09:18 AM
NBCat's Avatar
You may be able to find the procedure on YouTube. For example:
99xk8guy
May 28, 2024 09:36 PM
Skeeter
Sep 17, 2015 08:15 PM
JimMLiny
Sep 9, 2015 08:13 PM
Xkr x100
Sep 6, 2015 08:50 AM
XJsc-guy
Sep 2, 2015 11:43 AM
