Ac low pressure side
Old Sep 13, 2022 | 10:02 PM
Eggsy's Avatar
Default Ac low pressure side
Where is the ac low pressure side on my 2002 type s v8?
Old Sep 13, 2022 | 10:39 PM
kr98664's Avatar
On my '02 V6, the low side port is directly on the compressor, which is at the bottom forward left corner of the engine. I believe your V8 will be the same.
When searching for the low side port, it's actually easier to reach from the front of the car. Measure approximately 14" inboard of the inner edge of the front left tire, and approximately 3.5" forward of the front crossmember. Access is super easy once you realize where the port is located.
Old Sep 14, 2022 | 07:00 AM
Joedotcom's Avatar
hi
on a lot of post 2002 S-types, the ac low side is hehind R/H wheel, looking from the front of the car
so R/H side, lower wheel arch area, behind the wheel,back side of the car, just lie down and look under the car and you should see it
cheers
Joe
Old Sep 14, 2022 | 08:32 AM
Eggsy's Avatar
Old Sep 15, 2022 | 11:00 AM
Eggsy's Avatar
Nothing there that I could find
Old Sep 15, 2022 | 11:05 AM
Eggsy's Avatar
I don’t see anything there
Old Sep 15, 2022 | 11:24 AM
S-Type Owner's Avatar
Eggsy, where are you located? Is your S-type a 2002 or a 2002.5 (which would make it a 2003 in the States) ?
The last 6 characters of your VIN would narrow things down a bit...
Old Sep 15, 2022 | 11:32 AM
Eggsy's Avatar
I’m just outside of. Vancouver BC
VIN LAST 6
M41414
tks
Old Sep 15, 2022 | 11:43 AM
2002.5 starts at M45255
Should be on the compressor, Karl is right again.
Old Sep 15, 2022 | 07:31 PM
Eggsy's Avatar
I think I found it but not easily accessible
thanks all but I give up
cheers
Old Sep 16, 2022 | 02:42 PM
LLLA's Avatar
Can confirm.
fredpribyl
Aug 7, 2020 05:07 PM
fredpribyl
Aug 7, 2020 03:15 PM
annamiata
Apr 14, 2019 01:54 PM
donavin1
May 31, 2018 12:30 AM
TxToast
Aug 29, 2011 09:25 AM
