AFTERMARKET stereo
Old Sep 21, 2008 | 11:04 AM
ohsigmachi's Avatar
Default RE: AFTERMARKET stereo
I believe you will have to have a custom face plate/surround made.
Old Sep 25, 2008 | 05:56 PM
03 S Type's Avatar
No you don't have to go custom- if I'm not mistaken as long as your sterio is prior to 2002 ish- a double din will fit in place without much modification. If you DO need to order the faceplate- Metra makes a dash kit for the S Type. I have an '03 S Type with a 7 inch Kenwood DNX7120, and JL Audio 12W7 with JL Audio 500/1 amp. Good luck with your mods!
Old Sep 25, 2008 | 11:37 PM
Aeneas's Avatar
How many hours should it take for a non-expertto replace the radio in an early S-Type with some sort of aftermarket GPS/Bluetooth/DVD/2DIN replacement ?
Old Sep 27, 2008 | 07:10 PM
03 S Type's Avatar
Not too long- shouldn't be longer than an hour or two as long as you have everything in hand and/or have power tools. I think it took them about an hour to an hour and a half in the shop when I got mine done, and it took them a little longer because my "03 S Type" apparently didn't run off of the same dash kit as the "03 S Type" dash kit I ordered from the UK. Mine came in as a solid grey plastic piece and my dash is black. It didn't take too much manipulation to work but IMO it didn't come out as flush as I'd hoped. I have plans to go back and get a custom faceplate made when I have free time from school.
Old Sep 27, 2008 | 07:58 PM
Aeneas's Avatar
Are there any web sites which show a diagram series of how to penetrate in behind the radio to remove the old, exchange the connectors and replace with the new ?
If you replace a cassette radio with something with GPS and Bluetooth and maybe even TV, you might have new connectors to route into that space for antennae and brake signal.
Presence
Mar 13, 2016 02:21 PM
n8ertot
Oct 11, 2015 02:28 PM
hoodun
Sep 28, 2015 01:08 AM
