Aluminum Lugs?
Old May 14, 2016 | 03:19 PM
jeffn's Avatar
Default Aluminum Lugs?
Anyone tried aluminum lugnuts? Similar metal to the rims....
20x Polished 50mm Aluminum Extended Tuner Closed End Lug Nuts Lug Rims M12x1 5 | eBay
Old May 14, 2016 | 03:46 PM
Mikey's Avatar
Those are tapered seat lug nuts. Not suitable for our type of wheels and in fact potentially dangerous if used.
Old May 15, 2016 | 08:48 AM
jeffn's Avatar
Brilliant. Although maybe they used a 'stock', generic photo for the ad and actually ship the correct part as they do list it as: 'This part is compatible with 1 vehicle(s) matching 2007 Jaguar S-Type Base Sedan 4-Door 4.2L 4196CC 256Cu. In. V8 GAS DOHC Naturally Aspirated. '
What about aluminum lugnuts in general-not worth the bother?
Old May 15, 2016 | 09:22 AM
Mikey's Avatar
I'd worry about the threads stripping/pulling out given the torque load or eventual galvanic reaction between the nut and the stud.
The description confirms they are tapered seat type.
Old May 15, 2016 | 10:33 AM
jeffn's Avatar
I just emailed him about shipping flat seated lugs and described the problem with them loosening. Maybe just good old steel in this application. And yes, the lugs are more intimate with the studs than the aluminum wheels and were' 300' from the FL Atlantic spay so are assailed nonstop with salt spray.
richzak
Sep 10, 2023 12:53 PM
jagxkrtoofast
Mar 4, 2021 12:35 PM
Bigg Will
May 20, 2016 12:55 AM
malc4d
May 15, 2016 12:13 AM
jeffn
May 9, 2016 02:32 PM
