Another Problem with my S-type HELP
Old Nov 16, 2009 | 11:44 AM
bombu's Avatar
Default Another Problem with my S-type HELP
Hello all,
Sorry for keep posting, but I have encountered some small problem here and there.
By the way this problem now might not affect the performance of the car, but it is kind of dangerous if I drive in the hwy and want to pass some one.
The rear left turn signal is not working properly. When you sign, there will be 3 bulbs turned on, the back up bulb (suppose to turned on when you put your shift to R) and the rear left signal bulb. BUT they are not bright at all. Too dim, its like if those three lamps doesn't have enough voltage to turned it on, so it is dangerous because people won't see it.
By the way the WARNING that is suppose to show in Rear Signal Lamp Failure is not on. NO WARNING whatsoever.
Any idea ? is this some kind of a wiring issue ? I still have the coverage of the select edition. Will the dealer cover this ?
Thank you very much for your opinions.
Old Nov 16, 2009 | 06:00 PM
bombu's Avatar
Found the problem. It was the fuse eventually. Replace it and now everything works correctly.
Old Nov 17, 2009 | 06:03 AM
JOsworth's Avatar
Always best to change the easy things first. Glad for you that it was a simple fix.
colinc1444
Sep 14, 2015 07:54 PM
carcycle
Sep 7, 2015 04:14 AM
Numwen
Sep 6, 2015 12:30 AM
pocketrocket
Sep 3, 2015 07:44 PM
laserguy
Sep 3, 2015 02:02 PM
