Another Routine Maintenance Item That Needs Watching....
Old Jan 9, 2011 | 07:57 PM
RobGardnerBlack's Avatar
Originally Posted by androulakis
from my understanding it's a ROYAL pain to get those bolts out with the trans in the trans tunnel. There's barely room for an open ended wrench to get up in there...
Take it from the man who removed both bolts - Replacement requires the tolerance of a saint and the manual dexterity of a gynecologist
Old Jan 23, 2011 | 09:23 PM
aholbro1's Avatar
OK Jon, you were right....but I was lucky!
Lots less protection on this wiring on the 05 vs. the 03, but my 05 is not tight against crossmember, still no chafing.
I wrapped it with a sleeve anyway.
Also lucky with my shifter bolts, one very tight, the other snug, but it took maybe 1/16 of a turn.
Attached Thumbnails Another Routine Maintenance Item That Needs Watching....-img_20110123_161201.jpg   Another Routine Maintenance Item That Needs Watching....-img_20110123_161233.jpg   Another Routine Maintenance Item That Needs Watching....-img_20110123_162008.jpg
Old Jan 24, 2011 | 08:35 AM
Jon89's Avatar
That's certainly good news on your 2005 model. Glad to hear that your wiring harness is slack enough not to chafe and your ZF cable bolts were relatively snug. Now you have a couple less worries on that particular car....
Old Jan 24, 2011 | 03:17 PM
Brutal's Avatar
If you guys would buy a dang set of metric gear wrenchs, youde complain less about those bolts and other bolt/nut issues on the car. Theyre worth their weight in gold
Old Jan 24, 2011 | 03:19 PM
androulakis's Avatar
I own a set of metric gear wrenches , still limited access and a pita if you have to remove reinstall!
Hey brutal btw, any luck with the LS gas tank.
Take care,
George
Old Jan 24, 2011 | 04:23 PM
Brutal's Avatar
Take care,
George
NO AND IMAGINE THAT WHEN REGIONAL MANAGMENT GOT INVOLVED FINALLY THERE HAPPENED TO BE 500 GAS TANKS SITTING IN A WAREHOUSE IN UK FOR THE FUEL TANK RECALL FROM A FEW YRS BACK. BUT THEYRE A DIFFERANT PART NUMBER AND THATS WHY THEY DONT SHOW IN THE SYSTEM. A DEALER IN LOUISSIANNA JUST HAPPENED TO HAVE 1 IN STOCK. DONE AND GONE, FINALLY............
Old Jan 24, 2011 | 07:49 PM
aholbro1's Avatar
hmmm....no complaints here, bolt tightness easy enough to check/confirm, though I can see one expanding one's vocabulary of 4-letter words if one decided to remove and replace 'em.
Poet
Feb 7, 2025 02:18 PM
wonderwire
Oct 4, 2015 05:41 PM
reb1999
Sep 26, 2015 08:41 AM
PinnacleWax
Detailing / Car care
Sep 25, 2015 12:46 PM
